Need some TURBO help guys - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-18-2013, 12:41 PM Thread Starter
well I got an 04 powerstroke about 55,xxx on it (ik it doesn't get driven a lot) then one weekend we went out and were romping on it pretty hard, then no power an white smoke, so I figured maybe turbo seals because the coolant level hadn't changed at all. finally got the turbo out today and the vain plate was stuck and the shaft was split in 2. is their a full rebuild kit? or do I need a new turbo? what's my best bet here, any input would be great thank you.
jordanl is offline
post #2 of 6 Old 10-18-2013, 12:51 PM
sprksonu's Avatar
What do you mean when you say the shaft is split in 2? Is it the shaft that connects the compressor wheel to the turbine wheel? If so go get your self a new unit
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #3 of 6 Old 10-18-2013, 12:59 PM Thread Starter
ya the shaft the connects them, and new unit you mean a new turbo, weres a good place to get new ones or reman ones??
jordanl is offline
post #4 of 6 Old 10-18-2013, 01:12 PM Thread Starter
well hell while I got the teardown started im thinking I should egr delete it, an I heard theirs a spring mod so fuel pressure wont drop, do you guys have any kits you like more than others??
jordanl is offline
post #5 of 6 Old 10-18-2013, 04:33 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
I heard there is a spring mod so fuel pressure won't drop
Actually, the pressure will drop, but it raises the baseline by about 10 psi.
You could rebuild your turbo, but upgrading is a worthy consideration, especially if you have some damage from the shaft splitting and the rust.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #6 of 6 Old 10-18-2013, 07:59 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
Deleting the egr cooler would be really easy with the turbo out. I have sinester diesel egr delete and i like it. Blue spring is an update put out by ford, basically a longer fuel regulator spring to increase your fuel pressure.
Just like said above you can recondition and replace parts on your turbo but because of the damage it would be cost efficient to just upgrade your turbo.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
