6.0 White/blue smoke - Ford Powerstroke Diesel Forum
post #1 of 18 Old 10-17-2013, 10:01 AM Thread Starter
TrickyV10's Avatar
Having a bit of a problem here with my 2003 6.0. I recently put a MBRP 3.5" downpipe on and now have a white smoke w/blue tint out of exhaust at idle and at speed. No loss of power, no codes and EOT and WT are only about 7 degrees apart, no coolant loss or "burp" from degas bottle. Other recent mods are blue spring upgrade and muffler/cat delete, no tunes or programmers only Scan Gauge II for watching temps. Truck has 171,000 and I've only had it about 3 months. I am thinking possible turbo seal but how can I check this and can these be replaced? Thanks in advance.
TrickyV10 is offline
post #2 of 18 Old 10-17-2013, 10:13 AM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
Check this out, really good stuff right here.
Reconditioning a 6.0 Turbo!
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #3 of 18 Old 10-17-2013, 12:18 PM Thread Starter
TrickyV10's Avatar
That's great Thanks! I was looking at doing it myself and that's a great post seems like I could handle it. I'd a least like to try it before I go buy a reman unit. Thanks again
post #4 of 18 Old 10-18-2013, 05:32 PM Thread Starter
TrickyV10's Avatar
Got into the turbo today and other than cleaning it up it was in pretty good shape. No oil mess inside at all. Just at a loss as to why I'm smoking like a freight train. EOT and WT still under 10 degrees apart. At start up I can hear all injectors working, no codes and no stored codes. I'm going to pull the EGR valve and check it but could just that valve way over smoke me? One guy today told me I need a egr delete and his shop did them starting at about $2000. Sounds fishy because it's oil smoke I'm getting not coolant smoke. Any ideas out there?
2003 CCSB 6.0 SD
MBRP DOWN PIPE
MUFFLER/CAT DELETE
BLUE SPRING UPGRADE
HIGH IDLE MOD
SCAN GAUGE II
post #5 of 18 Old 10-18-2013, 05:53 PM
Smoking like a freight train is either the turbo, egr cooler, Hgs, or some kind of fuel contribution issue. You need to park your truck on a slight incline (that is the hood of the truck going down the slope) and pull your egr valve and look for fluid in your intake. If there is fluid it is probably your egr cooler if not the seal on one of your injectors could have blown.
An egr delete is easy to do and will same you $$ in the long run. You could do this easy with the turbo out already. I have a sinester diesel egr delete and it works great.
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
post #6 of 18 Old 10-18-2013, 05:57 PM
JustinOOO9's Avatar
Quoted: 521 Post(s)
Garage
you check your injector power balance? ficm volts, and the seal on the up pipe to the turbo?
also blue smoke seems to be turbo/injector issue and white smoke ir either coolant or fuel so sounds like:
1. fuel
2. turbo
3. both
there are a number of injector test you can perform with a monitor or barrowing a members ford AE program.
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #7 of 18 Old 10-18-2013, 07:27 PM Thread Starter
TrickyV10's Avatar
Thanks for the info. No coolant in the intake,just dry soot, cleaned egr valve seems to be working. FICM Voltage is reading good and going to check out some info on checking the injectors. Still no codes but smoke seems to be getting blacker and heavier.
2003 CCSB 6.0 SD
MBRP DOWN PIPE
MUFFLER/CAT DELETE
BLUE SPRING UPGRADE
HIGH IDLE MOD
SCAN GAUGE II
post #8 of 18 Old 10-18-2013, 07:41 PM
JustinOOO9's Avatar
Quoted: 521 Post(s)
Garage
anyway to monitor boost or the vgt cycle %? you could not be boosting enough to throw a code, but get higher fuel numbers giving you some smoke. also any unusual oil leaks esp on top end?
Justin,
post #9 of 18 Old 10-18-2013, 08:09 PM Thread Starter
TrickyV10's Avatar
Yes boost as high as 20 and VGT seems to be correct as it fluctuates from say 30 to around 75. It'll sit around 54 or so at a steady 60 mph. Have not really hammered it to see how high I can boost as not sure if I'm going to blow something up. I did do blue spring upgrade about a week before I started smoking. Hmmm....
2003 CCSB 6.0 SD
MBRP DOWN PIPE
MUFFLER/CAT DELETE
BLUE SPRING UPGRADE
HIGH IDLE MOD
SCAN GAUGE II
post #10 of 18 Old 10-18-2013, 09:33 PM
KillNThrill24's Avatar
I always thought blue smoke was oil related? Perhaps it's different on a diesel I can't say for sure as I don't know as much about them as I do gas engines. I'm gonna take a shot in the total dark here and say valve seals.
Reason(s)
No engine code (or codes at all)
Cleaned EGR valve
Checked turbo
Injectors working (from what he can hear)
No coolant in intake anywhere
OP did a spring upgrade
Those are just guesstimates based off the info I've gathered in this thread so don't shoot me down if I'm way off.. OP does it smoke ALL the time or just on start up/initial warm up?
2000 F350 Lariat CC LB, 00 Mustang GT, 01 turbo Cobra
KillNThrill24 is offline
Tags
6.0 , smoke , turbo
