Slightly rough idle after driving with oil leak - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-17-2013, 10:41 AM Thread Starter
Hey guys! I'm starting to run out of money on maintaining my 6.0 and now I have another problem. Once my truck hits operating temperature and is driven for about 20 minutes the idle starts to get a little rough. It's not really bad yet, but I can see it getting worse. To combat this I thought the oil was overfilled, so I changed it. However, when I was under the truck I noticed a lot of oil residue by the oil pan, transmission, and by the starter. I'm thinking I have a slight leak that is causing this problem?? Any suggestions?? You guys have helped me in the past. I wish I was as knowledgeable as you folks.
red0311 is offline
post #2 of 2 Old 10-19-2013, 12:38 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 449 Post(s)
Garage
Take a look at the ICP. Its up on the pass valve cover, if there is oil leaking at the sensor its shot for sure. Not sure what your seeing leak but it may have nothing to do with the rough engine
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
Tags
idle issue , oil leak , oil leaking , rought idle
