Coolant puke - Ford Powerstroke Diesel Forum
post #1 of 12 Old 10-14-2013, 03:40 PM Thread Starter
585Amarillo's Avatar
Coolant puke
I hooked up my pressure tester today and drove it after warm. Going up a hill WOT it hit 17psi on IDP's performance tune and it stays steadily at 13 while driving regular it pukes alot i just want to know if i have blown head gaskets or need a new degas bottle , the cap is a brand new stant.
K&N Intake
MBRP 4" Turboback
Silverline 6" Black Aussie Stacks
Zoodad Mod
Ford Updated parts
BPD FICM
Blue Fuel Pressure Spring
ARP Head-studs
Stock Injectors?
AirDog 165 Fuel pump
EGR Delete
SCT Custom Tuner By Inovative Diesel 5 tunes
10" Lift
37" Toyo Open Country M/T
4.56 Gears
18" XD Thump Black Wheels
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
Glowshift Gauges Trans.Temp., EGT, Fuel Pressure
585Amarillo is offline
post #2 of 12 Old 10-14-2013, 03:41 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
How full are you keeping your coolant? I run mine pretty low on the degas tank
2005 F350 CCLB FX4
2005 F350 CCLB FX4
juniorssrollin is offline
post #3 of 12 Old 10-14-2013, 03:48 PM Thread Starter
It's under the minimum now after it puked I haven't filled it up seems to run fine. no more puking.
K&N Intake
MBRP 4" Turboback
Zoodad Mod
Ford Updated parts
BPD FICM
ARP Head-studs
Stock Injectors?
EGR Delete
10" Lift
4.56 Gears
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
post #4 of 12 Old 10-14-2013, 03:55 PM
LSSBoy's Avatar
Same for me ? And i have a brand new updated degas cap
LSSBoy is offline
post #5 of 12 Old 10-14-2013, 03:57 PM Thread Starter
Is it fine to run it like that and my pressures are normal?
K&N Intake
MBRP 4" Turboback
Zoodad Mod
Ford Updated parts
BPD FICM
ARP Head-studs
Stock Injectors?
EGR Delete
10" Lift
4.56 Gears
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
post #6 of 12 Old 10-14-2013, 05:52 PM
Quoted: 2 Post(s)
You going by the minimum level on the tank or does yours have an updated sticker? I would only use a Ford OEM cap.
2005 F350 CCLB FX4
2005 F350 CCLB FX4
post #7 of 12 Old 10-14-2013, 06:36 PM
If u run elc it's supposed to be kept at the "lowest" full mark. Make u a bubble tester and see if you have air in the coolant side that will tell u if u have boost bleeding over from HGs. Which will be HGs may just have been overfill
Sent from AutoGuide.com App
- 2006 F250 Lariat 4x4 CC - Torreador Red
- EGR Delete, 5" Exhaust, ARP Studs c OEM HG, High Idle Mod, 4.5" Lift, 35" tires, Coolant Filter c ELC
scmedic85943 is offline
post #8 of 12 Old 10-15-2013, 01:18 AM Thread Starter
Im running the ELC coolant, how do I make a bubble tester?
K&N Intake
MBRP 4" Turboback
Zoodad Mod
Ford Updated parts
BPD FICM
ARP Head-studs
Stock Injectors?
EGR Delete
10" Lift
4.56 Gears
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
post #9 of 12 Old 10-16-2013, 02:32 AM Thread Starter
Today it wax at 15psi while I was cruising at 60mph.
K&N Intake
MBRP 4" Turboback
Zoodad Mod
Ford Updated parts
BPD FICM
ARP Head-studs
Stock Injectors?
EGR Delete
10" Lift
4.56 Gears
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
post #10 of 12 Old 10-16-2013, 03:12 AM
There's several ways I think bullet proof makes one. Look on YouTube. It's got to be under a load where your boost is pumping the most. There are several write ups on here and the net.
