2003 6.0 MPG Down and no power when cold. - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-14-2013, 06:55 AM Thread Starter
lolwutderp's Avatar
Hey guys, need a bit of help. Searching around helped a little bit not enough to not warrant a thread.
If I let the truck sit for 4-5+ hours, refuses to go over 2k rpm and sometimes blows blue/white smoke. Have a video of that issue. Once it warms up truck is 100%normal.
Also have an issue with my mpg's. Should I be constantly getting 11-14 mpg? I know my fathers 05 6.0 gets around 17-18 all the time, and its larger than mine.
Got the truck about a month ago, has 73k on it. Any of this be FICM, bad ff return spring or stuck EGR related? I have no monitor yet for the truck, so how could I check all my voltages/psi all that. My uncle has a bully dog tuner laying around for the 6.0 and would that be able to check all my voltages?
Im running full sythetic oil (changed 1k ago) and dud the fuel filters at the same time, only new thing i put on the truck is a 4" turbo back exhaust. I've already ran a bottle of seafoam and am curre fly running a bottle of cetane through the tank, but so far no luck.
Here's the video for the startup issue
Sorry for the link, on my phone at work.
https://www.youtube.com/watch?v=W2xW...e_gdata_player
lolwutderp is offline
post #2 of 8 Old 10-14-2013, 07:20 AM
Quoted: 770 Post(s)
Sounds like an injector issue but I'm not well versed on the 6.0's as the 7.3's.
Corey@CNCFAB is offline
post #3 of 8 Old 10-14-2013, 07:30 AM
Fummins90's Avatar
Any good scanner will be able to check FICM voltages. Make sure you check voltages while truck is cold. 48 volts.
-Jacob
PowerHungryPerformance --
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Fummins90 is offline
post #4 of 8 Old 10-14-2013, 07:32 AM
Quoted: 770 Post(s)
But his problem goes away once warmed up???
post #5 of 8 Old 10-14-2013, 07:45 AM
Fummins90's Avatar
I'm just trying to rude the FICM out completely.
-Jacob
post #6 of 8 Old 10-14-2013, 08:09 AM Thread Starter
lolwutderp's Avatar
Thinking about it, I know the alternators go bad prematurely, could it be that at start up my truck doesn't have the proper voltage, and as it warms up it supply more power to the FICM, I know a bad alternator killed my father's FICM.
I will check later and get and update thanks!
post #7 of 8 Old 10-14-2013, 08:20 AM
Fummins90's Avatar
Check those batteries as well.
-Jacob
post #8 of 8 Old 10-27-2013, 12:48 PM Thread Starter
lolwutderp's Avatar
OK update, checked my FICM today, steady between 48 and 48.4 volts, tested it twice. Alternator pushing out 13.2 volts without batteries, and batteries being a month old both read within the 12.78-12.83 range.
Should I do a new oil filter, only has 1000 miles on this oil, which was just switched to synthetic. Or should I check my fuel filters again?
Tags
2003 , 6.0 , coldstart , lowmpg , nopower
