HELP HPOP - Ford Powerstroke Diesel Forum
post #1 of 15 Old 10-13-2013, 03:07 PM Thread Starter
Garage
HELP HPOP
Ok, crap end to a great weekend! Driving home and 03 ex lost power and died. I have a sc2 and the icp was 535 psi and would drop to 430 psi when i hint wot. pulled to the to side of the road and it died and would not restart. the icp would not go above 550. After I had it towed home, I tried to restart it. It fired up and run like crap with no power. the icp was was around 550 and would drop when the throttle was depressed. The ipr was really high at 77%.
Could this be an o-ring or did the HPOP fail?
03 Excursion 210,000 running vivian tow tune, egr blocked off, new oil cooler last year, replaced the icr and 1.5yrs with and 05 part.
Robs97z28 is offline
post #2 of 15 Old 10-13-2013, 04:01 PM
I would suspect a leaking o-ring while running if your oil pressure drops lower than the pcm is expecting to see it will increase ipr tp try and compensate for the loss.
This may be what is happening.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 15 Old 10-13-2013, 08:08 PM
jtaylor75's Avatar
Man I had the same problem on an 03 international box truck and it kicked my a$$. The only way to figure it ou is to do an air test. You'll go broke if you try to throw parts at it. I put in a HPOP and two injectors before I did the air test. Turns out it was an o-ring in the stand pipe
06 CCSB FX4 Lariat
Studded and Deleted, Warren 190/100s, Barder Stage 4, Built Trans, AIS Water/Meth, S&B intake, 4 inch Exhaust
Next:
A fuel system
jtaylor75 is offline
post #4 of 15 Old 10-14-2013, 06:09 AM
PHYRMN's Avatar
03's and 04's don't have stand pipes and branch tubes like the later trucks. Your symptoms for an 03 definitely relate to High Pressure Oil leak. The 03 and 04 HPOP's have a history of getting weak before they die. Also, some 03's and 04's had a history of the HPOP discharge tube rubbing the HPOP cover and causing a leak there. I had a leaky discharge tube which I believe caused my premature HPOP failure. Ford or International, don't know which, came out with an updated HPOP for these years that allows more room between the discharge tube and the cover. The high IPR is a clue that the system is trying to compensate for low High Pressure Oil reading.
https://www.dropbox.com/s/l8t769irfp...2014.28.44.jpg
https://www.dropbox.com/s/fxvrghnk36...2014.28.30.jpg
Did I read correctly that you replaced your IPR with one from an 05?
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #5 of 15 Old 10-14-2013, 08:33 AM
jtaylor75's Avatar
03 and early 04's do have stand pipes that thread directly into the head. It is not very common for them to leak but they can. I've also seen that braided hose that connects the stand pipe to the oil rail leak. The best thing to do is an air test and see where it is coming from. If there is a leak in the discharge tube you should see it pretty quick.
06 CCSB FX4 Lariat
Next:
A fuel system
post #6 of 15 Old 10-14-2013, 08:35 AM
PHYRMN's Avatar
Agreed.....
PHYRMN is offline
post #7 of 15 Old 10-14-2013, 03:37 PM Thread Starter
Garage
Wow, thank you for the pics. that really helps a lot. Knowing this truck, that is what happened. I won't know until I tear it a part. The new cover is $430 p/n 3C3Z-9G805-AA from ford and it come with a new ipr valve.
No, I replaced the icp with an 05 and a new pig tail. That fixed the really bad oil leak I had. oil was everywhere under the body and trans.
post #8 of 15 Old 10-14-2013, 04:08 PM
PHYRMN's Avatar
I found my updated cover on ebay, seller didnt know what they had, gave like 60.00 dollars for it.
PHYRMN is offline
post #9 of 15 Old 10-14-2013, 04:11 PM
PHYRMN's Avatar
This is an updated 03, 04 cover here:
Ford 6 0 Diesel Hpop Cover 03 to Early 04 High Pressure Oil Pump Cover | eBay
PHYRMN is offline
post #10 of 15 Old 10-14-2013, 04:41 PM Thread Starter
Garage
How do i know this is a new updated cover and not an older version?
