2007 no start**urgent** - Ford Powerstroke Diesel Forum
post #1 of 15 Old 10-12-2013, 11:06 PM Thread Starter
Hey everyone, urgent need for help here.
I have a 2007 f250 that wouldnt start on day. I checked vitals and showed 0psi ICP so I thought oh good just icp sensor. Wasnt the case. Unplugged it and still no start. I then replaced the HPOP,IPR valve,oil cooler,standpipes and dummy plugs and I can now muster up a mere 370psi and still I no start. I am at my wits end. I figured the do it once cry once method would solve it but I guess not... any recommendations are greatly appretiated. Thanks
geardriven is offline
post #2 of 15 Old 10-12-2013, 11:37 PM
6.0newb!'s Avatar
Quoted: 17 Post(s)
Sounds like you need to replace the nipple on oil rail to injector o ring
06 f-250 ECSB xlt fx4, MBRP 4" cool duals, AFE stage 2 intake, BPD water pump, BPD egr cooler, stc update, stand pipes, dummy plugs, blue spring, late 04 up pipe, wicked wheel 2, PMM coolant filter, Riff Raff ic boots, t6-5w40, Rotella elc, leveling kit with 350 blocks, Pro Comp pro runner shocks, full Powerstop z36 brakes, PHP ficm tuner, insight cts w/egt, SCT x3 with canned tunes...... for now
6.0newb! is offline
post #3 of 15 Old 10-13-2013, 06:48 AM
PHYRMN's Avatar
Test your High Pressure Oil System, before you throw any more money at it.
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #4 of 15 Old 10-13-2013, 08:43 AM Thread Starter
I did air test origionally and I had a slight hiss from eash valve cover. I then pulled the covers and the hiss was loudest around the right hand standpipe. I air tested again and thats still the loudest point. I am suspecting the branch tube. Any way to know for sure?
post #5 of 15 Old 10-13-2013, 09:01 AM
PHYRMN's Avatar
Do you know if the Standpipes have been upgraded to the new style?
PHYRMN is offline
post #6 of 15 Old 10-13-2013, 09:10 AM Thread Starter
They werent but I replaced them with the upgraded versions
post #7 of 15 Old 10-13-2013, 09:15 AM
PHYRMN's Avatar
What about the STC fitting? You didn't mention it in your first post.
PHYRMN is offline
post #8 of 15 Old 10-13-2013, 09:17 AM Thread Starter
The new HPOP came with the updated stc connector
post #9 of 15 Old 10-13-2013, 10:52 AM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
Do you have a base oil pressure reading on the instrument cluster while cranking?
did you actually pull the whole standpipe out and check the lower o-ring where it goes into the branch tube?
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #10 of 15 Old 10-13-2013, 10:56 AM Thread Starter
Yes I have base oil pressure on the dash as well as filling the oil filter res quickly. Yes I replaced both pieces of the standpipes.
