truck not starting - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-12-2013, 06:07 PM Thread Starter
truck not starting
i have a 2004 F250. it will start and run all day long. but once you kill it, it won't start, it will crank over very fast like normal. if i start it and kill it immediately, it won't start back. i have to wait for a few hours before it starts again. i have changed out the fuel pump and fuel filters. does anyone have any ideas?
2004 f-250, 6.0, 4X4, auto, completely stock.
bgh1985 is offline
post #2 of 9 Old 10-12-2013, 06:12 PM
Joeshu1000's Avatar
You likely have a leak in the high pressure oil system. Once the oil thins out, the HPOP can't build enough pressure for the injectors to fire. Do a search for hot start problems and there are many threads that will lead you in the right direction.
Joe
2006 F350 XLT CrewCab 4X4
325/65R18
EGR Delete
Zoodad Mod
High-Idle Mod
Sinister Coolant Filter
ARP Head Studs W/ OEM Gaskets (Installed myself)
Upgraded Fuel Spring
Updated STC Fitting
Updated Oil Cooler Screen
Updated Dummy Plugs/Standpipes
6.4L Banjo Bolts
PHP Ficm Tuner
1/4 Mile 14.2 @ 93MPH
SCT Custom Tunes: MKM, Looney, SRL, SRLXX, Wildman and SPD w/ Early Lock up
Joeshu1000 is offline
post #3 of 9 Old 10-12-2013, 06:26 PM Thread Starter
does the oil thin out after starting then immediately(after 5 seconds) shutting off the truck? it won't start back after doing this either. i forgot to add, no codes show up on a scanner.
bgh1985 is offline
post #4 of 9 Old 10-12-2013, 06:37 PM
Joeshu1000's Avatar
There is no way the oil could thin out in 5 seconds. What kind of scanner were you using?
Joe
325/65R18
EGR Delete
Zoodad Mod
High-Idle Mod
Updated STC Fitting
6.4L Banjo Bolts
PHP Ficm Tuner
post #5 of 9 Old 10-12-2013, 07:12 PM Thread Starter
the code reader is an innova 3100 CanOBD2 diagnostic tool. i can't find any fuel leaks. i tried changing the oil, but that didn't fix it.
bgh1985 is offline
post #6 of 9 Old 10-13-2013, 08:43 AM
Joeshu1000's Avatar
That code scanner works if you have a check engine light. You're going to need a better monitor. I would suggest you read through this :Write Up: Monitoring the 6.0L PSD.
Joe
325/65R18
EGR Delete
Zoodad Mod
High-Idle Mod
Updated STC Fitting
6.4L Banjo Bolts
PHP Ficm Tuner
post #7 of 9 Old 10-13-2013, 09:05 AM Thread Starter
ill look into that write up. im not sure if it is relevant but about 5 months ago the fuel gauge would show false readings (i would fill up the truck and it would show half a tank then drop down to empty, then go back up to half a tank. just really erratic.) it finally fixed itself. i am a newb at these trucks so i have to ask a stupid question. the fuel pump i changed is the one on the frame. does the truck have another fuel pump?
bgh1985 is offline
post #8 of 9 Old 10-13-2013, 09:35 AM
Joeshu1000's Avatar
You are correct, that is the only fuel pump on the truck.
Joe
325/65R18
EGR Delete
Zoodad Mod
High-Idle Mod
Updated STC Fitting
6.4L Banjo Bolts
PHP Ficm Tuner
post #9 of 9 Old 10-13-2013, 09:50 AM Thread Starter
thanks for all the help. i found something that may help in this. if i take the cap off of the fuel filter (the one on top of the motor) and turn the key on, the bowl fills up with diesel, like it should, then the diesel in the bowl will bubble then the fuel level goes down.
bgh1985 is offline
