Post EGR delete problems...... - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-12-2013, 03:13 PM Thread Starter
Parker.ak.7's Avatar
2006 6.0L 164k miles
Just out a BD EGR delete and an MBRP exhaust on and it now runs like crap... It'll start. Idle sounds horrible... What the heck!!! I spent two and a half full days doing the delete cause it was my first time doing it.
My EGR valve's bolts are broken off in the intake manifold but the EGR valve is in and sealed ok it will be fixed but could that have something to do with it.
Also my oil filter housing has two broken ears on it so the seal may be not 100% on it... I didn't notice it leaking oil but it's also getting replaced ASAP.
Third but last on the front of my fuel filter there's a little manifold going to an aluminum fuel line that I bent. Could this be the cause if the rough idle??? I
Parker.ak.7 is offline
post #2 of 8 Old 10-12-2013, 03:47 PM Thread Starter
post #3 of 8 Old 10-12-2013, 04:56 PM
twoicebergs's Avatar
Quoted: 42 Post(s)
What the heck were you up to breaking bolts and things! Looking at what you have done to your fuel feed tube, you are probably having fuel delivery issues. If your EGR valve is not secured, you could expect it to pop off under pressure; however, you could expect a hard to remove one to stay in place until you are away from home, at night, it is raining, and without tools or a telephone!
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 8 Old 10-12-2013, 06:09 PM Thread Starter
Haha well here's the thing, there was already one bolt missing on my oil filter housing, and one piece of the cast came off when I was takin it off. I'm getting a new one haha its that simple.
My EGR valve was a weird one too. It already had a bolt snapped off in my intake manifold and some idiot torqued it to a zillion ft/lbs of torque so naturally it broke when I tried to take it off too.
post #5 of 8 Old 10-12-2013, 07:16 PM
Ordnance on coordinates
powerstrokeshellback's Avatar
Quoted: 53 Post(s)
Feedback Score: 7 reviews
i would start by fixing all the broken things.
2007 Ford F-250 XL 6.0L Powerstroke 4x4
God bless America, the Constitution and the Second Amendment.
Archoil gangbang - don't be the soggy biscuit
powerstrokeshellback is offline
post #6 of 8 Old 10-12-2013, 07:32 PM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Feedback Score: 3 reviews
I completely agree about that pinched fuel feed tube. I would start by trying to replace that and go from there
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is offline
post #7 of 8 Old 10-12-2013, 08:27 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
correct me if I'm wrong but the pics are a bit misleading. It appears to me that it's the return line (coming from the fuel pressure regulator) that is kinked.
The feed tube is the J tube that goes into the large diameter banjo bolt, it looks okay from what I can tell.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #8 of 8 Old 10-12-2013, 08:34 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Do you have a monitor? What is the Icp and IPR numbers, FICM volts, is the egr delete leaking... Are the up pipes leaking? Maybe you forgot to plug a sensor back in? It happens to the best of us. It's easy to over look the small things especially when your frustrated with other problems that happen while fixing your truck.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
