2003 6.0,no power when cold,hard miss at cruise - Ford Powerstroke Diesel Forum
post #1 of 18 Old 10-11-2013, 06:49 PM Thread Starter
techelard2's Avatar
Hi, I have a 2003 6.0 with 189,000 miles. When it is cold it has no power. It also will smoke white/blue smoke at random. When it does this I step down on it and it cleans up and takes off. At steady throttle has hard miss that cleans up on acceleration. I just did egr delete and now its worse. Any help..thank you.
techelard2 is offline
post #2 of 18 Old 10-12-2013, 08:08 AM
PHYRMN's Avatar
What are your FICM voltage readings?
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #3 of 18 Old 10-12-2013, 01:45 PM Thread Starter
techelard2's Avatar
48V..thought might be it but tested ok...wondering bout turbo service?
post #4 of 18 Old 10-12-2013, 09:28 PM
PHYRMN's Avatar
Stuck turbo vanes can cause the same issues your having. When was the last time it was cleaned?
PHYRMN is offline
post #5 of 18 Old 10-13-2013, 08:38 AM Thread Starter
techelard2's Avatar
Should have been 4 days ago when had it off doing egr delete..but didnt know was necessary. Just learning as I go on diesel. Going to do ffuel return spring while I have it back apart also. Do I need whole rebuild kit for turbo to clean it? Or just orings? Thank you for help.
post #6 of 18 Old 10-13-2013, 09:11 AM
PHYRMN's Avatar
Cleaning the turbo is fairly simple. What your looking for is a worn unison ring first off. Using a wire wheel or small grinding wheel to clean the carbon build up on all surfaces. Using a thin film of Anti Seize is also recommended.
Here's a pdf that will show you what to look for, and the cleaning process.
https://www.dropbox.com/s/dnkrvsvszs...%20rebuilb.pdf
PHYRMN is offline
post #7 of 18 Old 10-13-2013, 09:20 AM Thread Starter
techelard2's Avatar
I watched a youtube video on how to do it yesterday..wish had known when had it off..but not too difficult to pull again
post #8 of 18 Old 10-14-2013, 07:32 AM
Fummins90's Avatar
At idle, when cold?
-Jacob
PowerHungryPerformance --
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Fummins90 is offline
post #9 of 18 Old 10-14-2013, 02:02 PM Thread Starter
techelard2's Avatar
When I pulled intercooler line loose at the intake to do fuel pressure spring change I found little bit of oil in it. Is this a cause for concern?
post #10 of 18 Old 10-14-2013, 02:04 PM
PHYRMN's Avatar
No, its very common.
PHYRMN is offline
