What would you do? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-11-2013, 02:34 PM Thread Starter
DieselnDrums's Avatar
What would you do?
So I had a local shop do some diag on my truck as to why my truck was running rough. I got a call this morning saying that 4 and 5 injectors were performing at about 80% on the powerbalance test and that my FICM was at 40v. So I know I need to replaced the ficm no doubt about that but I was wondering about the injectors. Since the others are performing fine as of now and 4 and 5 are at 80% would you just replace the ficm and call it good if it does solve the rough running? I will also be adding rev-x too to see if that will help as well. I do plan on replacing the injectors with in a couple months anyways. but I'm just curious as to what you guys would do. Basically what I'm asking is if the ficm and rev-x does clear up the rough running, could I wait a couple of months to replace my injectors? Sorry If I am leaving any info out I'm a little short on time to write this.
06 f350, 6.0, 5 torqshift, egr delete, replaced oil cooler, SCT tuner, Head studs, MTW St 1 billet wheel, Custom tunes from GH.
DieselnDrums is offline
post #2 of 5 Old 10-11-2013, 05:23 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
Fix the FICM. Unless they switched out to a good FICM for the Power Balance, the results may be suspect; however, there is a good possibility that the test they did is valid. Rev X may work, or not. Of course, it doesn't always mean injector issues, but it usually is.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 5 Old 10-11-2013, 05:54 PM
6 L chevy eater's Avatar
One of my batteries being bad caused FICM voltage to be low and rough idling
2004 F250 ccsb
Skint Back Motorsports
Warren-HYBRIDS-- S400
FULL Billet Twisted Diesel Built Tranny
10.90@124 on fuel dammit
6 L chevy eater is offline
post #4 of 5 Old 10-11-2013, 06:48 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
this is why I will always swap in a known good FICM and retest. no guessing what the ficm is or isn't causing.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #5 of 5 Old 10-11-2013, 07:47 PM Thread Starter
Thank you guys for your responses. I doubt they put in a known good FICM and retested it. But when I got the call from him and he said it was at 40v I was actually a little shocked because a couple weeks prior, when the rough running started to happen I checked the FICM and it was at 48v and 47.5v when cranking. So I thought for sure that my FICM was in good working order. Mind you my truck has been sitting for little over two weeks from the time I hooked it up to the scan tool from my work and to the phone call I got a couple of days ago from the guy doing the diag on my truck. just seems odd, Have you guys ever had a FICM just completely crap out with no warning even if you keep tabs on it?
