HELP - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-10-2013, 08:35 PM Thread Starter
HELP
2003 F 350 6.0,181000 miles,stock. Start's hard when cold and run's rough after it does start and smokes a lot for about 20 second's. I took it to Ford and they said no codes were coming up, I thought maybe a injector, they said no, that's as far as I got with them. Once the truck get's up to temp it run's fine, but when it's cold it has no power and blow's a lot of blue smoke when i get on the pedal, no power.and a lot of bucking after i get it up to 55 and it ****'s into overdrive. I did a volt check on the FICM and got a reading of 47 with the key turned on, then cold start and still a reading of 47, ANY IDEALS
Powerstrokeless is offline
post #2 of 9 Old 10-10-2013, 09:02 PM
poorboy1964's Avatar
Quoted: 2 Post(s)
Symptoms do sound like a bad FICM, I've heard of them being bad showing OK voltage. 03 are know to have wire chafing problems start at the 3 FICM connectors and check wear spots to see if something has worn through. Do you have anything to monitor engine with like scangauge or????
Tom
2003 CCSB 4X4 6.0 Born on 5/03 Tuned by Vivian, 4" Turbo Back Exhaust, Edge CTS w/EGT, Coolant filter. ELC. fuel pressure gauge,
2002 SCLB 4X4 7.3 Stock
poorboy1964 is offline
post #3 of 9 Old 10-11-2013, 05:13 AM
Quoted: 50 Post(s)
I completely agree
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDC Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #4 of 9 Old 10-11-2013, 10:33 AM
Fummins90's Avatar
Time to ship off that ficm. Have your batteries been replaced recently or been dead? Drop in voltage/rise in amps=bad ficm.
I'd personally recommend Ed at Ficmrepair.com We use him for our own personal vehicles.
-Jacob
PowerHungryPerformance --
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Fummins90 is offline
post #5 of 9 Old 10-11-2013, 11:50 AM
PHYRMN's Avatar
What about Stiction?
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #6 of 9 Old 10-11-2013, 12:09 PM
Fummins90's Avatar
At 180,000?
-Jacob
post #7 of 9 Old 10-11-2013, 06:19 PM Thread Starter
I used Hotshot in my last oil change, with no results.The batteries were replaced less than a year ago. I don't have a engine monitor. I drove the truck today and it is getting worse,I have plenty of cranking power but the truck seem's to barely want to start, warm or cold. It also smells like it is running very rich when at idle.
post #8 of 9 Old 10-12-2013, 08:15 AM
PHYRMN's Avatar
Originally Posted by Fummins90 View Post
At 180,000?
At 180,000 miles, absolutely. Injectors can build up with coke at any age of the injector.
OP, having a monitor for 6.0's is a must, depending on what type of monitor you prefer can be a bit pricey, but knowing whats going on under the hood will help you diagnose problems before they get expensive, and help you diagnose whats happening in this case also.
PHYRMN is offline
post #9 of 9 Old 11-12-2013, 08:26 PM Thread Starter
Update, Haven't changed FICM yet and the truck batteries have been dead the last two morning's. After charging it takes up to five tries to start it, it will start and stall. I have put some Power Service in the fuel and that has seemed to help it run a little better, not smoking nearly as much on start up and running better after warm up with a liitte more power but I still feel it missing when I get on the pedal.Once the truck is started {after charging batteries} it start's the rest of the day, not quick but starts. Could the FICM be draining my batteries overnight, the batteries are not even a year old? Also still have the strong smelling exhaust.
