engine miss while cold - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-10-2013, 06:17 PM Thread Starter
I need some opinions on a problem. I have a 05 f250 with a set of warren 175 injectors with about 7000 miles on them, a swamps 58volt ficm. My problem is when engine is cold it has a miss under acceleration. It idles fine and runs good for the most part as long as I don't try to get in a hurry. When it warms up to 190 it runs fine. I have a Gillette regulator spring in a stock style fuel system pressure is 90 at idle. It's a dead head style gauge setup under hood so I'm not sure how much it drops while driving. It has new filters. I don't think it's fuel though I think it's injector stictation. I was running Rotella synthetic with about 8000 miles. It started running like this so I changed to schaeffer synthetic. I had already planned on running that oil but was going to wait till 10000 miles. Problem is still their. What do y'all think should I try Rev-x in my synthetic oil? What should I try next? thanks.
turdblow is offline
post #2 of 7 Old 10-10-2013, 06:23 PM
6 L chevy eater's Avatar
ADD SOME REV X ON YOUR NEXT OIL CHANGE. SHOULD TAKE CARE OF YOU PROBLEM
2004 F250 ccsb
Skint Back Motorsports
Warren-HYBRIDS-- S400
FULL Billet Twisted Diesel Built Tranny
10.90@124 on fuel dammit
6 L chevy eater is offline
post #3 of 7 Old 10-10-2013, 06:24 PM Thread Starter
Also I have no codes.
turdblow is offline
post #4 of 7 Old 10-10-2013, 06:26 PM Thread Starter
I just changed the oil like 500 miles ago.
turdblow is offline
post #5 of 7 Old 10-10-2013, 06:32 PM
add 2 4oz. bottles of rev-x as asap. u should notice a diif
2004 F250 ccsb
post #6 of 7 Old 10-12-2013, 02:48 PM
I literally just had this exact same issue in my '05.
I had 3 bad injectors in the driver side bank.
Was NOT a stiction problem.
Rotasol is offline
post #7 of 7 Old 10-12-2013, 08:45 PM
PHYRMN's Avatar
You had a set of Warren 175's with only 7000 miles on them?
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
