High pressure oil leak repair - what else to replace? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-09-2013, 03:57 PM Thread Starter
I have an '06 with about 153k on it. Never had any internal work done on the engine. It seems that I have a high pressure oil leak somewhere that is causing hard starts when the engine is warm.
Also, periodically when I am driving, the injector pressure will not get above 2k, even though the engine is under heavy load and the boost is over 20psi. Normally, I would expect over 3k.
Anyway, the injectors did check good with the engine warm, and I am planning on leaving the truck at my dealer so that they can check them cold. I will know more about them then.
I have been watching my EOT, and on smooth highway stretches it has been right around 15deg higher than the water. I do not have a programmer or chip, but do have a scangage II
I do have to let the truck warm up, even on warm mornings - 60deg, or else I get the sluggish shifting type issue. No excessive smoke either.
Enough rambling on...
When I get this truck worked on, I definitely want to fix it once, and not have to go back for a while. What should I do to it?
Budget is a concern, and the truck is not mine. It is my work truck, but it is my daily driver, so I want it reliable.
Thanks
'06 F350 Lariat with 8' utility bed. 130k miles - stock and still original engine internals.
acro is offline
post #2 of 2 Old 10-14-2013, 02:04 PM Thread Starter
Well, i got two quotes from my dealer.
"Minimum" repair is about 2k. That is a new HP oil pump and replacing the dummy plugs. $850 labor.
Option 2 is what they recommend based on our conversations. Replace the oil cooler, egr delete, new injectors and hp oil pump and replace the dummy plugs.
$6400 which includes $1500 labor.
I know I could beat those prices going to a non dealer, but there would be the question of warranty, should something go wrong down the road.
Comments?
acro is offline
