turbo rebuild....? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-09-2013, 07:43 AM Thread Starter
turbo rebuild....?
Ive got blue smoke and oily turbo. Had the intake off the other day and found a bunch of side to side play, but not into housing yet, no in and out play. Does anyone know how long id be able to run with turbo like this before it gets into rhe housing? Could this be why I get awful fuel mileage?
feedatron is offline
post #2 of 6 Old 10-11-2013, 09:40 AM
Fummins90's Avatar
Is it using oil?
-Jacob
PowerHungryPerformance --
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Fummins90 is offline
post #3 of 6 Old 10-14-2013, 04:56 AM Thread Starter
Hasent used enough to notice. Smokes like crazy right after warm up then on acceleration...also started to notice the idle shacking a little...any ideas on that?
post #4 of 6 Old 10-14-2013, 06:25 AM
Fummins90's Avatar
Turbo causing a boost/oil leak
-Jacob
post #5 of 6 Old 10-14-2013, 02:58 PM
6speedpowerhouse's Avatar
It's not a hard rebuild and you can buy the seal kit online.
Ford 6 0 L Powerstroke turbocharger Rebuild Kit | eBay
I did mine and it only took about an hour after I pulled all the parts from the hot tank. Just pay attention to how you took it apart and even take a few pictures once you get the compressor wheel and back plate off. The compressor wheel is reverse threads. There was a thread here with all your torques if I find it I will post it here.
2004 F-250, 6.0L Powerstroke, ZF6, studded/deleted, blue spring, AFE CAI, straight piped, SCT Xcal 3 tuner, updated turbo oil line, some gauges, Dynamat behind the dash, fresh clear on the outside, Kenwood stuff in the doors/dash, 2005 grill, 33's, and some other minor things to make it look good
6speedpowerhouse is offline
post #6 of 6 Old 10-14-2013, 03:03 PM
Rebuilding the 6.0 VGTurbo - Ford Truck Enthusiasts Forums
Here's a write up. Good luck
