Cylinder 1 Contribution Error, Still. -- Video Included - Ford Powerstroke Diesel Forum
post #1 of 25 Old 10-09-2013, 06:39 AM Thread Starter
Gus_hauler's Avatar
Long story short, I was getting an "Injector 1 Contribution Error". I replaced the injector with a new one from Ford. Same error came back after about two drives.
Cylinder 1 is the forward most on the passenger side, right?
The only other issue I could think of was maybe a High Pressure Oil leak at the injector? So I took off the valve cover, and ran the engine. Below is a link to the video. There is a bit of oil coming out of the top of each injector, but from what I've read, that's normal right?
I would really appreciate you taking a look at the video, and letting me know if you see anything strange.
Thanks
Powerstroke 6.0 Passenger Side Running - YouTube
2004 F-350 Crew Cab LB Dually
"Longhorn Hauler" edition
New Heads!
ARP Studs
Banks Six-Gun with PowerPDA (For gauges only)
EGR Delete from IPR
Rotella ELC
New Turbo from Garrett
Gus_hauler is offline
post #2 of 25 Old 10-09-2013, 07:53 PM Thread Starter
Gus_hauler's Avatar
Could someone please confirm the location of cylinder 1?
New Heads!
ARP Studs
EGR Delete from IPR
Rotella ELC
post #3 of 25 Old 10-09-2013, 11:58 PM
Passenger side is odd numbered bank. #1 is front cylinder.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #4 of 25 Old 10-10-2013, 06:19 AM Thread Starter
Gus_hauler's Avatar
Thanks. Has anyone ever gotten a bad injector right out of the box from Ford?
New Heads!
ARP Studs
EGR Delete from IPR
Rotella ELC
post #5 of 25 Old 10-10-2013, 07:16 AM
Contribution is a inferred calculation by the pcm so this could be a false signal.
Did you make any actual physical tests to verify? IE compression test; check for voltage at the plug in etc.
post #6 of 25 Old 10-10-2013, 07:19 AM Thread Starter
Gus_hauler's Avatar
Unfortunately I don't have a compression tester. I know I need to pick one up. I see harbor freight has some cheap ones, do they actually work on the 6.0's?
I haven't checked voltage, but would like to. Can you tell me how? I did peel back the wire wrap and inspected the wires, they all seemed to be in good shape.
New Heads!
ARP Studs
EGR Delete from IPR
Rotella ELC
post #7 of 25 Old 10-10-2013, 10:30 AM
Yes the harbor freight one will work thru the glow plug hole.
As for checking voltage from the ficm you can unplug at the pass thru at the rocker box
The member Southend knows the ohm values of the injectors by heart. Actually I think they are tattoed to the back of one hand LOL He knows a bit of checking injectors.
post #8 of 25 Old 10-10-2013, 01:39 PM
southend's Avatar
Let me see if this link works. .... Ohm tested #4 injector.
Sent from my phone that somebody didn't help me get.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #9 of 25 Old 10-10-2013, 01:44 PM
southend's Avatar
I'm pretty certain oil coming out from around your oil rail tips is not ok.
Here, check this out. ...... http://www.accuratediesel.com/shop/243.html
southend is offline
post #10 of 25 Old 10-10-2013, 01:50 PM
southend's Avatar
Whoa, just checked out the video. ...... that is not ok. Remember at idle your oil rail is seeing about 500-600 psi. Get on the throttle, and you will see upwards of 3000+psi. I think you need to investigate the oil rail nipple orings and maybe the upper orings in the injectors also. There is a kit for those too. Let me see If I can find it. Be back. ........
southend is offline
