Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Motor problems
Old 07-05-2008, 11:41 AM
BigRed BigRed is offline
Broken...
Turbo squeal
Hey guys I am ready to go get a 7.3! I am having a problem with my truck that sounds like a turbo squeal, it is an intermittent noise and any fluxuation in the throttle causes it to go away. Sometimes it does it a idle and others it will do it at 1/8th throttle. It sounds just like squeaking brakes rolling up to a stop sign but doesn't stop until I give it more or less throttle. Any ideas? Is it a turbo bushing or something to that nature going bad??
Old 07-06-2008, 07:29 AM
Broken...
Sunday
Old 07-06-2008, 07:45 AM
!!!PainTrain!!! !!!PainTrain!!! is offline
TED NUGENT FOR PRESIDENT
Is it possible it could be a problem with one of the vanes in the turbo itself. And as you give it more or less throttle you are causing a difference in boost, which is opening and closing the vanes?
Old 07-24-2008, 04:52 AM
Broken...
I think I should have just put that 03 turbo on it... LOL
Old 07-24-2008, 05:12 AM
Abrannan19 Abrannan19 is offline
sounds like a cracked up pipe..get under the truck..look and see if you can se any soot around the flex section of the up pipe.
Old 07-24-2008, 05:36 AM
Broken...
What causes the up pipe to crack?
Old 07-24-2008, 05:52 AM
crappy flex section.
Old 07-24-2008, 06:04 AM
Broken...
Yep, just went and looked at it and sure does have a crack! Now if I could only get the tranny issues figured out I would be good...
Old 07-24-2008, 06:27 AM
im a good guesser..LOL
I know the high pitch squeal..I heard it one too many times!
I wont hear it ever again though!
Old 07-24-2008, 05:26 PM
Too late for that buddy lol. I'll never give it up haha.
Hopefully here soon I will be in the same boat
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
