new oil cooler/ no start - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-06-2013, 08:13 PM Thread Starter
i just put in a new oil cooler and a coolant filter. I also put in the blue spring while in there. after finishing and trying to start I found 3 codes (U0105, U0306, P2552) also reading 0.0 volts on the ficm. I have the idp ficm tuner on there with srl+ which I don't think they would be the problem. just not sure if I lost my ficm or what?
islero is offline
post #2 of 6 Old 10-06-2013, 08:45 PM
Might not have a connector plugged in all the way on the ficm or possibly bent a pin over in the ficm. Check your connections.
jpott62 is offline
post #3 of 6 Old 10-07-2013, 05:37 AM Thread Starter
I will check them but I didn't disconnect the ficm. so I guess the harness go pulled a little bit and lost a connection.
islero is offline
post #4 of 6 Old 10-07-2013, 06:47 AM
Did you prefill the HPOP oil resivor before ya buttoned it all up? If you didn't it can take up to 30 miles driveing before it works all the air out.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #5 of 6 Old 10-07-2013, 09:05 PM Thread Starter
Jpott62 you were right. The first plug on the ficm was pulled out slightly.
islero is offline
post #6 of 6 Old 10-08-2013, 04:03 AM
Good news glad I could help
jpott62 is offline
