Whitish blue smoke - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-04-2013, 06:40 PM Thread Starter
Whitish blue smoke
Hey everyone ive got an 03 f250 6.0 with 146,000 miles, full exhaust, sct tuner, banjo bolts, fuel spring, swamps 40hp ficm, adrenalin hpop, updated drain tune, stock injectors and head studs an gaskets as far as i know and stock intake...... Over the last month or two ive had whiteish blue smoke out the exhaust very intermittently and has now gotten to the point where it pukes oily smoke at ilde after about 5 min from bone cold. While driving i get no smoke at all until i stop.
The other day i decided enough was enough and i bought the garrett rebuild kit and rebuilt it and alas.... It smoke just as it dis before for the last two days.... There is oil dripping out of two of my exhaust clamps and on the exhaust tip soooo i am ABSOLUTELY sure it is oil without even a question.. I also thought i may have a drain restriction so i bought the updated drain tube and it also did not help. So my question to anyone who can help me before i kill myself is do you think i have a turbo drain restriction inside by the hpop screen or something..... A bad turbo that is obviously beyond rebuilding??... Or could i have screwed up the rebuild?? And btw there is ZERO oil in the up pipes to the turbo..
ANY AND ALL HELP is greatly appreciated thanks everyone!
Sent from AutoGuide.com App
Fastnova1976 is offline
post #2 of 4 Old 10-04-2013, 07:25 PM
trade it for a 7.3 good luck
sean andreano is offline
post #3 of 4 Old 10-04-2013, 07:28 PM Thread Starter
If i wanted a truck slower than a bobcat i would have bought one thanks for the help
post #4 of 4 Old 10-09-2013, 06:44 PM
Chasing the same problem right now. I have one of Adrians turbos in the garage ready to go on tomorrow if I have time.
06 F250 CCSB 4" Superlift with Bilstien 5100 series shocks, studded, deleted, stc, stand pipes & dummy plugs, turbo oil lines, oil cooler, blue spring, 6.4 banjo's, ARB front bumper, 35x12.5x18 Toyo All Terrain 2's on 18x9 Pro Comp 1079 wheels,4.10 gears, catless 4"mbrp turbo back, ccv mod. sct x3 on Looney & edge cts w/fuel pr and turbo timer.
'05 F550 Fontaine conversion 2wd dually all stock with edge cts
H10F250 is offline
