Shuddering and black smoke?? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-04-2013, 09:27 AM Thread Starter
Bought a 05 F250 few months back and just now really have had the chance to drive it.
While going down the highway in OD I will go up a slight rise that requires a bit more power to maintain speed. The truck will start missing and spitting black smoke, the boost pressure also follows the smoke clouds.
My 2 lines of thinking are either its the transmission being a pain and trying to down shift but not completing the shift (if I step on it and force the shift the miss goes away)
Or there some sort of problems around 2k rpm... any ideas or what I should check? thanks
ricke9590 is offline
post #2 of 8 Old 10-11-2013, 11:09 AM
mdiesel's Avatar
anyone?
i have same issue
2006 F250 6.0L
mac intake
ZooDad Mod
Accufab polished Elbow
sct innovative tunes
Cat delete with cool duals
14.069@95.62MPH
someday
water/meth
headstuds
MAP - Mid-Atlanic Powerstrokers member
mdiesel is offline
post #3 of 8 Old 10-11-2013, 11:23 AM
Fummins90's Avatar
High pressure oil pump not allowing engine to rise in rpm therefore creating the bog.
-Jacob
PowerHungryPerformance --
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Fummins90 is offline
post #4 of 8 Old 10-11-2013, 11:38 AM
mdiesel's Avatar
I was affraid of that but checking it looks to be a pain
2006 F250 6.0L
mac intake
ZooDad Mod
14.069@95.62MPH
someday
water/meth
headstuds
mdiesel is offline
post #5 of 8 Old 10-11-2013, 11:41 AM
Fummins90's Avatar
What ICP pressure are you getting at idle?
-Jacob
post #6 of 8 Old 10-11-2013, 12:48 PM
mdiesel's Avatar
650 to 700
2006 F250 6.0L
mac intake
ZooDad Mod
14.069@95.62MPH
someday
water/meth
headstuds
mdiesel is offline
post #7 of 8 Old 10-11-2013, 01:08 PM
Fummins90's Avatar
Yours may just be beginning to fail.
-Jacob
post #8 of 8 Old 10-11-2013, 06:16 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
More than likely it is an injector or 2 on the way out. However, without data from your monitor it could be a number of things. What is your turbo doing? What is your EBP? The RPM, ICP and IPR under load when the problem is occurring is needed as well. How about the FICM voltage?
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
