06 6.0L idle jumping around - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-03-2013, 03:44 PM Thread Starter
RY86's Avatar
Hey guys
The odd time when I am in traffic or I pull up to a stop light and the truck drops to idle it sometimes jumps 100-200RPM from idle. If you press the brake pedal light enough the rig will actually move/jump well the idle is jumping around. The engine is completely stock with no tune. Only thing I have done recently is I have installed the blue spring for the fuel return. I have no CEL coming on well this is going on. Any ideas??
Ryan
2006 Powerstroke 6.0
Blue spring mod
CAT EC-1
Coolant filter
Garrett Powermax turbo
Tuned by gearhead performance
MBRP 4" tubro back exhaust 5" rolled tip
4" ICON suspension lift
35" toyo MT's
BMF Novakanes
RY86 is offline
post #2 of 3 Old 10-05-2013, 03:59 AM
mxrider777's Avatar
Unplug your icp sensor it should be on your valve cover and see if it runs better, if it does you need a new sensor or if there is any oil on it you need to change it also. Also inspect the pigtail and wiring going to it. Hope this helps
2003 F250 CCSB 6.0l
12' lift
43" Michelin xls
sinister coolant filter
zerex elc coolant
edge insight
Egr Delete w/ coolant reroute
mxrider777 is offline
post #3 of 3 Old 10-05-2013, 04:09 AM
Idle is controled by the pcm. You need to read pcm values to see what is changeing.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
