Hard acceleration issues - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-02-2013, 07:21 PM Thread Starter
Mauch2's Avatar
Hey Im curious as to what might be happening with my truck, when I drive it normally i have no issues with power or anything of that sort, but now when i decide to punch it and get moving the truck starts to sputter a little bit and im not getting the full effect that i used to. I havent changed anything recently and this just started happening. I do have a fuel pressure gauge that reads roughly 55-65 regularly and about 50 when foots on the floor. I did do the blue spring and havent really noticed too much of a difference, it also is tuned with a SCT flash ford programmer, and i have straight stacks on it. I really have no idea whats going on, my next project is the whole head bolt and gasket fix, but i dont think this is whats the issue, any ideas???
Mauch2 is offline
post #2 of 6 Old 10-02-2013, 07:24 PM
drivininidaho's Avatar
Quoted: 67 Post(s)
is the turbo spooling? your vanes could be sticking and not spooling like it should.
Lyndel
'04 F25 SD CCSB
studded, and having some issues.....
drivininidaho is offline
post #3 of 6 Old 10-02-2013, 07:55 PM Thread Starter
Mauch2's Avatar
yeah it is spooling, how would i check the vanes though? my boost gauge does say its pushing pressure but how do you check if its doing it right
Mauch2 is offline
post #4 of 6 Old 10-05-2013, 03:57 AM
Sorry for the thread jack I also have a similar problem with mine but i'm noticing some coolant oozing out of the degas bottle under hard acceleration. When I check the degas bottle when the engine sat overnight the coolant was at the min level after a long drive pop the hood and check the level and the coolant was way above the max line, to where you can hear air exiting or entering through the cap when pressurized. Not sure if that's a H/G or EGR cooler or maybe both ?
2006 F-250 6.0L Powerstroke, K&N intake with S&B filter, 3.5" - 5inch Mbrp Cat back exhaust with muffler delete pipe, Garret Powermax, Performance Machine Coolant filter, SCT Livewire w/Innovative Diesel Xtreme tune, High idle mod, Glowshift gauges Egt, oil temp, fuel pressure. 2.5" leveling kit, 35X12.50R17 Nitto Trail Grappler, Rancho Dual Steering Stabilizer, Rancho 9000XL Shocks.
doombugie is offline
post #5 of 6 Old 10-05-2013, 01:32 PM
Roll Tide Nation!!!
J_BAKE_04_PSD's Avatar
Quoted: 4 Post(s)
Garage
subscribing. My 04 is doing the same thing. Just noticed it today on the highway when I try to accelerate hard, the truck sputters.
J_BAKE_04_PSD is offline
post #6 of 6 Old 10-07-2013, 11:49 PM
Sputtering
My '04 yesterday had some very hard misses as I accelerated when it was still a little cold. It ran fine the rest of the day.
This morning it started fine and would go at a slow speed but under acceleration or at 50 and above it would hardly run.
Drained water seperator and replaced fuel filters. No change. Don't know what to check next.
Racerman is offline
Tags
acceleration , fuel pressure , head bolts , head gasket
