Long start - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-30-2013, 03:43 PM Thread Starter
585Amarillo's Avatar
Long start
I replaced both dummy plugs, both stand pipes , and the STC fitting.
Now it has a long crank before it starts does any body have a idea whats going on could it be air in the oil and i need to go beat the crap out of it to get the bubbles out of it?
K&N Intake
MBRP 4" Turboback
Silverline 6" Black Aussie Stacks
Zoodad Mod
Ford Updated parts
BPD FICM
Blue Fuel Pressure Spring
ARP Head-studs
Stock Injectors?
AirDog 165 Fuel pump
EGR Delete
SCT Custom Tuner By Inovative Diesel 5 tunes
10" Lift
37" Toyo Open Country M/T
4.56 Gears
18" XD Thump Black Wheels
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
Glowshift Gauges Trans.Temp., EGT, Fuel Pressure
585Amarillo is offline
post #2 of 8 Old 09-30-2013, 03:46 PM
tonyf250's Avatar
Get it started and drive it! It will work its way out.
'05 F-250 CC 4x4 6.0
6" Fabtech lift
BANKS exhaust
Airaid intake
SCT tuner
w/Matt's tunes!
Auto Meter Pro-Comp Ultra-Lite boost,pyro,tranny
A-pillar gauge mount
Zoodad
mod
35"x12.50"x20" Mikey Thompson Baja ATZ's
20"x10" MotoMetals
tonyf250 is offline
post #3 of 8 Old 09-30-2013, 04:56 PM Thread Starter
alright ill get on it also forgot to mention im getting the p0300 random misfire, im thinking its part of it
K&N Intake
MBRP 4" Turboback
Zoodad Mod
Ford Updated parts
BPD FICM
ARP Head-studs
Stock Injectors?
EGR Delete
10" Lift
4.56 Gears
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
post #4 of 8 Old 09-30-2013, 05:02 PM
tonyf250's Avatar
That likely is the problem. Others on here will chime in I am sure.
6" Fabtech lift
BANKS exhaust
Airaid intake
SCT tuner
w/Matt's tunes!
Zoodad
mod
20"x10" MotoMetals
tonyf250 is offline
post #5 of 8 Old 09-30-2013, 05:03 PM Thread Starter
what causes the miss fire? i get my AE tomorrow so i can mess with things!
K&N Intake
MBRP 4" Turboback
Zoodad Mod
Ford Updated parts
BPD FICM
ARP Head-studs
Stock Injectors?
EGR Delete
10" Lift
4.56 Gears
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
post #6 of 8 Old 09-30-2013, 05:16 PM
tonyf250's Avatar
I am still learning my AE! If it gets air in it the injector may not fire.
6" Fabtech lift
BANKS exhaust
Airaid intake
SCT tuner
w/Matt's tunes!
Zoodad
mod
20"x10" MotoMetals
tonyf250 is offline
post #7 of 8 Old 09-30-2013, 05:22 PM Thread Starter
PM me some tips to get me started, if you would.
K&N Intake
MBRP 4" Turboback
Zoodad Mod
Ford Updated parts
BPD FICM
ARP Head-studs
Stock Injectors?
EGR Delete
10" Lift
4.56 Gears
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
post #8 of 8 Old 10-01-2013, 03:57 PM Thread Starter
Its back to normal starting , I have some data I would like to know if its normal from my AE
FICM Main power- 48.50 at all times
Injector control pressure Desired - 580.1 at idle
Injector control pressure Regulator - 23.44 at idle
Injector control pressure - 582.95 at idle
K&N Intake
MBRP 4" Turboback
Zoodad Mod
Ford Updated parts
BPD FICM
ARP Head-studs
Stock Injectors?
EGR Delete
10" Lift
4.56 Gears
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
