Cylinder 1 isn't pulling its weight - Ford Powerstroke Diesel Forum
post #1 of 1 Old 09-29-2013, 08:33 PM Thread Starter
Gus_hauler's Avatar
So when I replaced my heads recently I also replaced the injector on cylinder 4 because I was getting a "cylinder contribution" error. That error went away, but then immediately afterward I started getting the same error for cylinder 1.
So this weekend I finally got around to replacing the injector for cylinder 1 with a new one from Ford. It worked! For like two drives, then the error came back.
The engine seems to be running fine. So, any ideas on what else I should check? Wiring? I wonder how the system measures a cylinder's contribution anyway?
Thanks,
2004 F-350 Crew Cab LB Dually
"Longhorn Hauler" edition
New Heads!
ARP Studs
Banks Six-Gun with PowerPDA (For gauges only)
EGR Delete from IPR
Rotella ELC
New Turbo from Garrett
Gus_hauler is offline
