Looking to do an EGR delete and more. - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-29-2013, 09:29 PM Thread Starter
Parker.ak.7's Avatar
so like i said. EGR delete.... how dificult of a process is that and can i get some links to a video or manual on it. also looking at XDP's website and they've got an EGR, Ford Head Gaskets, Ford Exhaust gaskets, ARP Head Studs, Ford Factory oil cooler kit and screen, Ford factory intake gaskets and ford factory turbo o ring kit and hardware.
2006 6.0, 165k miles.
how dificult would this all be to install?
Parker.ak.7 is offline
post #2 of 5 Old 09-30-2013, 12:58 AM
KCCO!!
kells17's Avatar
if all you are doing is an egr delete...a good days work...getting the intake manifold off along with your egr cooler shouldn't take more than a couple of hours. switching out part of your y-pipe and then buttoning her back up will be the longest part... I haven't looked, but I'm sure there are videos on youtube on how to remove everything...it's not difficult, just time consuming...
getting to the gaskets, head studs, etc...you could be down a couple of days...with 165K on your engine, it would probably be a good idea to get your heads checked...that's where the couple of days comes from depending on how quick a machine shop can get them back to you...
oil cooler is not difficult either...rebuild is quite straight forward and there is a youtube video on that complete with torque specs...
all in all, considering time down for the machine shop...a few days give or take...I did everything myself minus the head work and I was back up and running in a week...there are many members here who have done rebuilds on the exact same job it seems your planning and they/we can all offer great advice...do some homework, there are a lot of good threads on here that can help you out tremendously...good luck with which ever way you decide to go...and again...if you need guidance or assitance...don't hesitate to ask
2004 F-250 Lariat CCSB
Studded, Deleted, Cold Air, Fog Light Mod,
IPR HF Coolant Filter, High Idle, Atlas 40 FICM,
CCV, Edge Insight CTS, ZooDad, BPD Oil Cooler,
4" Banks Monster Exhaust, Fumotos, 05 Harley Headlights,
Blue Spring, Kill Switch, 03 Turbo and 6.4 Banjo Bolts
VA Strokers
757 Diesel
kells17 is offline
post #3 of 5 Old 09-30-2013, 08:26 AM
I add a question about delete procedure.
I have seen EGR coolers welded solid, but on one video a guy had plugs that he just tapped into the ends. Where to get such plugs?
2007 F350 dually/5000 lb, 12' tall camper.
Kajtek1 is offline
post #4 of 5 Old 09-30-2013, 08:33 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Just get freeze plugs for engine blocks. I'd have them welded in their so there is no chance for an issue. Can't remember the size off the top of my head. Look at the sticky threads in the 6.0 forums... Lots of head gasket write ups with lots of pics. It will take the average backyard mechanic at least 3-4, most times I'd say a week. Definitely get the heads checked. There is a thread on having the 6.0 heads checked properly in the stick threads too. Good luck and have fun!
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #5 of 5 Old 10-08-2013, 07:49 PM
I started oil cooler replacement job and removed the intake manifold before it got very dark.
"Somebody was there before" >>> several bolts that should hold smaller stuff are missing and the harness is just laying on the engine, so they were definitely professionals. (PO was utility co)
Now I can take a look at EGR cooler and via side hole I see about 1/4" tubings inside what per my observation is bulletproof cooler as factory one has radiator-style passages.
Is it possible that in 2007 Ford put better coolers or maybe PO did that?
How can I tell for sure it is bulletproof EGR cooler?
Kajtek1 is offline
