Oil Temp Question - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-29-2013, 06:34 PM Thread Starter
06kngrnch84's Avatar
Oil Temp Question
Just did a water pump replacement, coolant flush and put in new ELC. Before the install with my water pump being bad, my temps were really off and they would jump all around. Since I changed the water pump my coolant temps are more steady and where they r suppose to be. Only thing is I'm noticing now my my oil temps r high, apparently my cooler is clogged. I'm running about 17-20 delta. Question is, what harm is this doing to my truck. Plan on getting a new cooler soon but just wondering if further damage could be done of it driven? My wife is using it most of the time for now taking my kid to and from school but she doesn't drive it a lot everyday some days not at all. No hauling or towing anything anytime soon either. Any help is appreciated
Jackson, MS. 2006 Ford F-350 SRW King Ranch FX4 Crew Cab, All Stock, 160,000 miles
EGR Delete
Updated HPOP Fitting
Updated Standpipes and Dummy Plugs
ELC Coolant
Coolant Filter
Scan Gauge II
New Oil Cooler
Blue Spring Kit
'04 Metal Cold Side CAC Tube
06kngrnch84 is offline
post #2 of 4 Old 09-29-2013, 06:42 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
The main concern with running high oil temps is the risk of rupturing the oil cooler causing oil to be pumped into the cooling system. Which then you will need another water pump and all rubber coolant hoses. As you know, the stock 6.0 water pump has plastic impellers and when there is oil in the coolant it warps the plastic impeller and turns all coolant hoses so soft that you have no choice but to replace them. It can wait... But how long is anybody's guess. Could be a week, month...
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 4 Old 09-29-2013, 07:13 PM
drivininidaho's Avatar
Quoted: 86 Post(s)
^^totally agree, def start on planning to replace it. also maybe look into getting a coolant filter.
Lyndel
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
'04 F25 SD CCSB
studded, and having some issues.....
drivininidaho is offline
post #4 of 4 Old 10-16-2013, 11:23 AM
Texas Proud
charlie.thomas's Avatar
I agree and also reverse flush your radiator with your regular water hose pressure then rinse it out with distilled water. Usually I have seen on all the ones that I do is that if the oil cooler is plugged most of the time the radiator is also partially plugged up too.
"Feel the Fear and Do It Anyway"
2007 F250 King Ranch
Alligator Performance EGR Delete
5" AFE air intake
Blue Spring Mod
High Idle Mod
4" Turbo back straight exhaust
SCT Livewire TS tuned by the best, "Tony Wildman"
New block bored .020" over
New heads ported, polished, and decked
ARP Head studs
And other goodies
Lifted on 35" Toyo Open Country MT
charlie.thomas is offline
