Lower ECT's and drop in MPG. - Ford Powerstroke Diesel Forum
post #1 of 44 Old 09-29-2013, 06:32 PM Thread Starter
6.boom's Avatar
Over the past week and a half my ECT's have been a bit lower than normal. It normally is around 186-190ish range. Now its 180-184. According to my insight my average mpg (i do mostly city driving) is 13. It has dropped down to 9. I am not missing coolant, and it is running fine. It has been getting colder, but not enough to affect my ECT temps. Am i just being paranoid?
I've got 99 problems and my 6.0L is all of them.
Want to creep? Instagram: lynntaraa
6.boom is offline
post #2 of 44 Old 09-29-2013, 07:13 PM
Quoted: 58 Post(s)
Sounds like your thermostat is getting week, as in these trucks they fail open as a safeguard. Running around unloaded, ECT should be around 190 to 195f, where the thermostat begins to open. And engine temp is tied to fuel mileage - particularly with diesels. The ideal temp for diesel efficiency is 203f.
Also, some states may already be switching to winter blend diesel, so prepare for the annual 2 - 3 mpg drop to begin
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #3 of 44 Old 09-30-2013, 05:14 AM Thread Starter
6.boom's Avatar
Would my thermostat going bad cause just my readings to be off? Because my MPG doesn't seem like its getting 8-9, yet it reads like that. Sorry if thats a dumb question
6.boom is offline
post #4 of 44 Old 09-30-2013, 05:38 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Yes cold diesel's do not perform as well as efficiently. (just so you know that took 3 people to try to spell that word)
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 44 Old 09-30-2013, 07:02 AM Thread Starter
6.boom's Avatar
So since my thermostat is going bad, not only will the readings be off but the truck itself will not perform accordingly.
6.boom is offline
post #6 of 44 Old 09-30-2013, 07:27 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
I don't think running 4-10*f cooler is going to result in 2-3 mpg loss. I'd check your hand calculated mpgs and go from their
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #7 of 44 Old 10-01-2013, 08:22 AM
TNFireman's Avatar
I wish I saw a lower coolant temp. Mine needs a water pump its been heating up in traffic. Just need to find the time to do it.
I vote thermostat and the cooler weather coming in. Mpg loss can be different driving, fuel quality, injectors wearing out. Have you been getting fuel at the same place?
94 F350 xlt, 4x4, 7.3 idi turbo cc/lb 36" maxis buck shots getting paint!!!
06 F2504x4 PSD KR, H11studs,175/75's from warren ordered!!,idp tuned ficm egr delete IDP Custom tunes mbrp 5" edge Insight cts with pyro and isspro fuel pressure gauge, air dog 165 to put on and turbo to order RCD 68mm or powermax modded
IAFF Member International Association of Fire Fighters
TNFireman is offline
post #8 of 44 Old 10-01-2013, 04:03 PM Thread Starter
6.boom's Avatar
Oh gosh i hope its not my injectors. Yes I have been fueling up at the same places.
6.boom is offline
post #9 of 44 Old 10-01-2013, 04:54 PM
Quoted: 8 Post(s)
Keep us informed....
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #10 of 44 Old 10-01-2013, 05:50 PM Thread Starter
6.boom's Avatar
Will do! Thank you for the help
6.boom is offline
