2006 6.0 blowing blue smoke at take off - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-29-2013, 04:04 AM Thread Starter
Exclamation 2006 6.0 blowing blue smoke at take off
Looking for some help on why my 6.0 after warmed up would be blowing blue/white smoke at redlight on take off. Just changed all injectors and half ficm board. Any help or guidance would be appreiciated. Thanks
deanleger is offline
post #2 of 6 Old 09-29-2013, 08:57 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 488 Post(s)
Garage
You might have a bad injector ?? Somewhat common with rebuilt injectors, try putting a heavy dose of fuel supplement or some 2stoke oil in the fuel tank and see if it works itself out.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #3 of 6 Old 09-29-2013, 09:12 AM
npccpartsman's Avatar
Quoted: 5 Post(s)
Your EGR cooler might be leaking if you still have one. Or you could have a leaking turbo seal.
I Bleed Razorback Red
Ford Makes It, International Shakes It, Casserly Fuels It, KC Turbo Spools It, SCT Tunes It, and Trucks Unlimited keeps her Rockin the Road
npccpartsman is offline
post #4 of 6 Old 09-29-2013, 09:53 AM
mhatlen's Avatar
Quoted: 488 Post(s)
Garage
Did this start after the new injectors?
7" Icon/Carli Lift
Atlas40
mhatlen is offline
post #5 of 6 Old 09-29-2013, 12:22 PM Thread Starter
It started after I changed the injectors. The egr is still in. About 2 months after I had them changed #2 injector blew out dumping raw diesel into the cylinder resulted in diesel dripping out of my exhaust. Had it replaced, and the same problem with the smoking started again. I change oil and filter every 5000 miles, fuel filters every 10k and flush my coolant every 60k miles with putting standyne additive in every tank.
post #6 of 6 Old 09-29-2013, 04:46 PM
mhatlen's Avatar
Quoted: 488 Post(s)
Garage
You may want to run a contribution test on it. You are not loosing coolant are you?
If not its all fuel your most likely seeing.
You can use a IR temp gauge at all the exhaust manifold outlets and see if there is a cylinder lower on temp then the rest of them. this will be the case if a injector is not closing or possibly leaking on a cylinder.
7" Icon/Carli Lift
Atlas40
mhatlen is offline
