Turbo randomly runs at minimun duty cycle with no throttle??? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 09-28-2013, 04:40 PM Thread Starter
gotta_gofast's Avatar
Quoted: 60 Post(s)
So I've been chasing issue after issue with this 6.0L... I've gotten it to the point where the truck is running good AND THEN...
I first noticed a deep rumble of an exhaust note during idle that cleared (followed by the turbo whistle) after applying any sort of throttle. I looked into the limited PIDs that the SCT livewireTS offers and noticed that during random traffic light stops the VGT duty cycle drops to 11-12% (resulting in zero boost) when normally I would see 44-48%. I don't know if what I am reading on the SCT is the duty cycle commanded by the PCM or actual vane postion. When I accelerate the turbo lights and it returns to its normal 40ish% dc under modest acceleration. Anyone have similar experience with this issue? I'm looking to nip it before it becomes a bigger issue. I want to blame the VGT solenoid or EBP sensor but the SCT shows some wild number for EBP so I can't trust it as a reliable source.
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #2 of 13 Old 09-28-2013, 04:54 PM
Beauxroux's Avatar
This is normal behavior. The vanes periodically change position while idling to prevent them from getting stuck. Mine does this too. Sounds like the turbo is turning on and off every 20 seconds or so.
Beauxroux is offline
post #3 of 13 Old 09-28-2013, 05:00 PM
Quoted: 50 Post(s)
I was going to say the same thing. It's what the latest strategy does to exercise the turbo and prevent sticking of the unison ring.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDC Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is online now
post #4 of 13 Old 09-28-2013, 07:45 PM Thread Starter
Quoted: 60 Post(s)
I know of the vane sweep... this is while in drive at a stop light. I hear the turbo whistle disappear and it gets a real deep V8 idle. If I watch the SCT it will be 11-12% duty cycle (it does not vary or sweep, it will stay in this state the entire duration of the stop light) when you fuel it, it has a slight hesitation until the SCT reads 39-42% and the turbo lights. It did this to me just about every time I let off earlier in the day. However, I just towed a friends car on my tandem axle trailer for 55 miles and never had any hiccups. Weather temperature related??? Hmmm... I suppose I will wait until the symptoms are replicable. Its hard to trouble shoot something that happens away from home but won't show itself when you have your tools out.
post #5 of 13 Old 09-29-2013, 08:54 AM
Normal operation. Many variables go into the sweep ( low duty cycle) of the vanes.
Your chasing a problem that doesn't exist IMO.
SHOOTER22250 is offline
post #6 of 13 Old 09-29-2013, 09:41 AM
Beauxroux's Avatar
There's nothing wrong with your turbo. Most Sct tunes have this feature in their strategies, maybe this is why you are just noticing. Mine does this at traffic lights as well. I'll be driving, come to a stop, then hear my turbo "turn off" and get a deep V8 rumble for 20 seconds or so then it'll turn back on and start whistling. Turbo also turns back on once you give it any throttle. I have a straight pipe and I can hear it happening very clearly. People in traffic usually start looking around and open their windows to try to figure out what's going on. There is literally nothing for you to be worried about. I find that it happens more when the weather is hot. It's completely healthy. Like previously stated... You're chasing after a problem that doesn't exist. I admire your concern and determination to resolve issues with your truck before they become worse, this just isn't an issue. Quite frankly, if it wasn't doing this, I would suggest you get your ECM updated to the latest strategy so that it does. All of that worrying for nothing!
post #7 of 13 Old 09-29-2013, 05:49 PM Thread Starter
Quoted: 60 Post(s)
Man that's weird. If you're headed down the interstate at 65 and let off throttle it drops to minimum, too? I've had the same program/tune on for 9 months now and never experienced this until yesterday and I watch my parameters religiously. I've always known the truck to sweep the vanes when idling in neutral or park but never in drive or while the truck is moving.
post #8 of 13 Old 09-29-2013, 10:23 PM
Beauxroux's Avatar
It does it while in drive, yes. It only does it if your RPMs are below a certain threshold.
post #9 of 13 Old 01-11-2014, 11:45 AM Thread Starter
Quoted: 60 Post(s)
Just an update. The problem was becoming more frequent. If I apply throttle it stays at 14% (open) and lags like crazy sometimes and run normal others. Eventually it just stayed at 14% and one morning triggered a P0470 code so I replaced the EBP sensor and tube and all is normal again. No annoying lag or random drop in exhaust note and throttle response.
post #10 of 13 Old 01-11-2014, 06:06 PM
Beauxroux's Avatar
Glad to hear you got it figured out.
