Bottom rad hose popped off oil/coolant - Ford Powerstroke Diesel Forum
post #1 of 11 Old 09-27-2013, 09:21 AM Thread Starter
Cbankston1447's Avatar
I made a short trip and everything is running great! I parked it for the night and the next morning the bottom radiator hose had blown off and spewed a mixture of coolant and oil on the ground. Upon further inspection, I noticed the degas bottle had the same mixture. I pulled the oil cooler to inspect and saw clean coolant in the oil cooler. Now I'm not sure if that was the leak. The oil is very clean( no coolant) so my question is, is there another place the oil could get introduced into the coolant?
Cbankston1447 is offline
post #2 of 11 Old 09-27-2013, 09:23 AM Thread Starter
I'm sorry, it's an 05 6.0
post #3 of 11 Old 09-27-2013, 09:25 AM
sargar's Avatar
Trans cooler in the radiator.
Tuned, Deleted, Filtered, Monitored...all the usual stuff.
sargar is offline
post #4 of 11 Old 09-27-2013, 09:34 AM Thread Starter
I just bought the truck and notice the radiator looked new. How can you tell if the oil is engine or tranny. Isn't trans fluid red? This stuff was black.
post #5 of 11 Old 09-27-2013, 10:42 AM
sargar's Avatar
Check your trans fluid for color and/or coolant contamination. You could have a previous failue that has been repaired, but the oily funk not cleaned out.
sargar is offline
post #6 of 11 Old 09-27-2013, 12:00 PM Thread Starter
Yeah, that could be true. I'll check that out and let you know what I find. Thans for the info.
post #7 of 11 Old 09-27-2013, 03:06 PM Thread Starter
Checked the trans fluid, very clean, no coolant. I suppose I'll just throw it back together, flush the crap out of the cooling system and let ur rip! Unless anybody thinks there may be just that one little thing I might need to check while in in it this far.
post #8 of 11 Old 09-27-2013, 09:40 PM
sargar's Avatar
Once you are sure you have all the oil out of it, look into replacing all the rubber coolant hoses.
sargar is offline
post #9 of 11 Old 09-27-2013, 10:06 PM
ZMANN's Avatar
Quoted: 1655 Post(s)
I want to know why the bottom hose blew off
I would check and make sure the cap is good
if you did have more that 18 psi( bad head gaskets ) and the cap didn't release pressure it's going to want out pretty bad
We Miss you Ronnie
ZMANN is offline
post #10 of 11 Old 09-27-2013, 10:29 PM
sargar's Avatar
Perhaps bad clamp with a recent radiator replacement? Maybe the oil lubed it up good? Maybe a combination of the two? Maybe not?
sargar is offline
