egr delete - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-24-2013, 01:43 PM Thread Starter
Exclamation egr delete
im thinking about buying a egr cooler delete kit for my 2007 f250 6.0l powerstroke???? but aint that gonna trigger the service engine light???? or should i get one of them bulletproof upgraded egr cooler???
1st ford is offline
post #2 of 4 Old 09-24-2013, 01:55 PM
poorboy1964's Avatar
Quoted: 2 Post(s)
It will set the wrench light, the only way around it is to buy a tuner and turn it off. if you are not going to do custom tuning or if you have diesel emission testing done where you live I would go with one of the bullet proof ones.
Tom
2003 CCSB 4X4 6.0 Born on 5/03 Tuned by Vivian, 4" Turbo Back Exhaust, Edge CTS w/EGT, Coolant filter. ELC. fuel pressure gauge,
2002 SCLB 4X4 7.3 Stock
poorboy1964 is offline
post #3 of 4 Old 09-24-2013, 01:58 PM
Term3's Avatar
Quoted: 2 Post(s)
Some trucks get a CEL and some don't, it depends on your trucks PCM flash version. If your state doesn't have emission testing there's no logical reason to have EGR cooler. Keep in mind a lot of guys keep their EGR valve electrically connected after doing a delete as there can be issues with fan clutch engagement and turbo vane stroke at start up if the EGR valve is missing.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #4 of 4 Old 09-24-2013, 03:28 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 552 Post(s)
Garage
A 2007 will absolutely set off a wrench light.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
4" SS exhaust
58K Miles on it
2000 Watts of McIntosh Bliss
mhatlen is offline
