2005 with fuel smell in cab and around truck - Ford Powerstroke Diesel Forum
post #1 of 13 Old 09-24-2013, 01:39 PM Thread Starter
I can't find any leaks but I can smell the fuel after the truck has been run. I also am getting a smell through the deforster when I run it. What do I need to be looking for. Is there a common leak that I can fix myself or is it off to the stealer.Thanks.
moralem is offline
post #2 of 13 Old 09-24-2013, 03:14 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 466 Post(s)
Garage
Take a real close look at the fuel filter housing on top of engine. Most likely place for a leak. The o-ring is known for leaking at the cap. Should be dry up there so anything wet is most likely diesel.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #3 of 13 Old 09-24-2013, 03:32 PM
ZMANN's Avatar
Quoted: 1590 Post(s)
and just below up front at the regulator housing seen here with all the arrows pointing to it
We Miss you Ronnie
ZMANN is offline
post #4 of 13 Old 09-24-2013, 03:38 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I had a leaking egr valve and man, you could smell it in the cab something fierce! So ya a leaking cap/o-ring would do the job real nice!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 13 Old 09-25-2013, 06:17 AM Thread Starter
Thanks for the input, I am going to start looking under the hood this weekend and see what I can find.
moralem is offline
post #6 of 13 Old 09-25-2013, 06:35 AM
Quoted: 5 Post(s)
Open the degas bottle cap and see if that's where the smell is coming from or if you see oily nasty in the coolant bottle.
05 Extended Cab FX4
SCT w/ Gearhead Tunes
Ble-Blah mod...
Edge Insight CTS w/EGT
PHP Tuned FICM-Hercules
a2elvis is offline
post #7 of 13 Old 09-25-2013, 06:41 AM
shenanigans
junior125's Avatar
Quoted: 1575 Post(s)
Garage
there are plugs on the back of the cylinder heads, make sure fuel isn't coming out of there, had it happen on mine
Mike
2005 CCSB F250 4X4
junior125 is online now
post #8 of 13 Old 09-25-2013, 06:43 AM Thread Starter
Ok, checking the degas bottle for nasty oily stuff does not sound good. What issue would I be looking at if I were to find oily nasty crap in there or the odor of fuel was eminating from there............not good to leave me hanging like that man Thanks.
moralem is offline
post #9 of 13 Old 09-25-2013, 07:05 AM
Quoted: 5 Post(s)
Sorry... Here is the long and short.
If there is diesel fuel in the cooling system, then you most likely have a crack in one of the cylinder heads. Now I hate to jump to conclusions, so lets start by looking for the obvious like the previous posts.
The fuel filter housing are on the top of the engine is the most likely spot for leaks, especially during climate change. The o rings shrink up and leak, which is most likely the issue.
05 Extended Cab FX4
Ble-Blah mod...
a2elvis is offline
post #10 of 13 Old 09-25-2013, 07:17 AM Thread Starter
I was thinking more of a leaking head gasket but a cracked cylinder head is bad news......The truck is not my daily driver so I just started to notice the smell on the weekends when I would use it for chores etc.....I will start with the basics and see what I come up with.....might be time for a new truck anyway with it being 8 years old and with a 175K miles on it.
moralem is offline
