low circuit # 2 injector - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-23-2013, 02:10 PM Thread Starter
JustinOOO9's Avatar
Quoted: 583 Post(s)
Garage
so last week while playing with first custom tune got a low circuit code for #2 injector P0264. but then flurry of other codes so i returned truck back to stock and for 4 days everything has been just great. got back from a 310 miles trip towing a 5k camp trailer. all my temps were great and stuff. but then just today got a p0264 code for the # 2 injector again.
2 months ago replaced both batteries and alt because i didn't check the alt after 2 dead batteries and then because of that it fried my FICM so i did the premium ficm job at ficmrepair.com
I have checked every wire connector i could reach and even removed air filter and stuff to check other wires and everything looks/ feel seated in the connectors. my ficm volts are like 47.5-48 cranking and driving.
anyone know if i can do like an OHMS test on the #2 injector wire or? Just looking to try and fix myself before i spend money for the techs that sinister diesel uses. (great guys but wanting to save $)
I have googled, binged, read and read and read all i find are post where people mentioned the problem but nothing on diagnosing it. truck runs fine on starting, driving etc....
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s, JW Vbody.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #2 of 6 Old 09-24-2013, 07:17 PM
Did you check your FICM connections? I had the low circuit code come up for #6 and #4 when I didn't fully seat one of them after doing some work. The truck ran fine after I put it back together and never lit the MIL but eventually the connector worked it's way loose, causing a miss and contribution code on #4. I believe #2 is wired to the center connector of the FICM. Of course it could be a million other things too, but it's easy to check and since you recently replaced the FICM, worth looking into.
'05 F-350 Crew cab XLT 4X4
6.0/Automatic
EGR and cat deleted, Insight CS, Sinister coolant filter, complete update kit.
Haze is offline
post #3 of 6 Old 09-24-2013, 07:22 PM Thread Starter
JustinOOO9's Avatar
Quoted: 583 Post(s)
Garage
yesterday i removed the air filter and re connected the 3 ficm harnesses and made sure i heard a click so im hoping so haha. i also checked every connector i could get my hands on and disconnected and re-connected.
anyone know how to do an ohms or volts test? if the code comes back i read that a bad injector coil could cause this as well.
Justin,
post #4 of 6 Old 11-01-2013, 04:14 PM
305f250's Avatar
Hey Justin,
What ever happened with this? I am getting the same thing right now
305f250 is offline
post #5 of 6 Old 11-01-2013, 05:32 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
1 ohm plus or minus 0.2
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #6 of 6 Old 11-01-2013, 08:22 PM Thread Starter
JustinOOO9's Avatar
Quoted: 583 Post(s)
Garage
Originally Posted by 305f250 View Post
Hey Justin,
well it's a little embarrassing or the part is bad...
I found the number 2 injector is ran to the center of the 3 main harnesses on the FICM. So i unplugged the injector wire on injector side re clipped and found that the center ficm harness made a click sound when i played with it... and I swear i double checked that all 3 harnesses clicked haha. so far no codes have come back yet .
p.s. I removed air cleaner, intercooler tubes and cleaned and reconnected every connector i could find that day too figured might as well.
if everything checks out do a power balance test with your edge unit and see if it really is different.
Justin,
