Low Fuel Pressure - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-23-2013, 11:27 AM Thread Starter
raptorfever660's Avatar
Garage
Question Low Fuel Pressure
Oh guys and gals I am battling low fuel pressure. I have been fighting this for over a year and still not getting anywhere. I have replaced the HFCM twice (Last time was just a new pump) My fuel pressure ranges from 43 to 55 at idle and 35-55 WOT. I have done the regulator rebuild with a blue spring after the first HFCM and it kept it from dropping below 45psi. Then this summer while pulling the boat (4100lb load boat+trailer+gear) it went crazy and would bounce from 20psi to 60psi. I bought a new pump thinking it might be going bad and now I am back to staying above 42psi. I change the filters every other oil change (9-11000 miles) and always use motocraft filters. This is a stock truck no tuner (Won't hook it back up until fuel issue is solved). I am going to test FICM voltage this weekend and see what it shows. Does anyone know if there is a screen in the tank that could be plugged or restricted? Just want to try and weed out the free and cheap stuff first.
Any advice would be great.
Thanks
2005 F-250 Crew Cab 4x4 6.0 Powerstroke
FASS Fuel System 150gph
SCT Livewire TS
Everything Else Is Stock
raptorfever660 is offline
post #2 of 9 Old 09-25-2013, 01:42 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
What are you using to read your fuel pressure . And where is the fuel gauge hooked up? I can't tell you how many times I've seen guys replace parts when it turns out to be the fuel gauge. When fuel pressure is "bouncing" during steady throttle (either idle or WOT) it's usually the gauge. At very least test the gauge or hook put a borrowed one on there.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 9 Old 09-25-2013, 02:07 AM Thread Starter
Garage
The gauge is hooked up to the test port on the filter housing. I've used 3 different gauges. Even an ol trusty mechanical.
Sent from AutoGuide.com App
SCT Livewire TS
post #4 of 9 Old 09-25-2013, 06:05 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 445 Post(s)
Garage
Some year trucks have filter screens in the tank at the inlet. IIRC its 2003-2005 but don't quote me on the model years that do.
With that problem fuel pressure is usually ok at idle then drops away under throttle.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #5 of 9 Old 09-25-2013, 08:41 AM Thread Starter
Garage
[QUOTE=mhatlen;6729905]Some year trucks have filter screens in the tank at the inlet. IIRC its 2003-2005 but don't quote me on the model years that do.
Ok thanks.
SCT Livewire TS
post #6 of 9 Old 09-27-2013, 07:58 AM Thread Starter
Garage
Ok so I changed filters again and idle its at 50psi wot it bounces from 60 to 40 and keeps bouncing. Any ideas?
SCT Livewire TS
post #7 of 9 Old 09-27-2013, 08:17 AM
Term3's Avatar
Did you check the intake screen IN the tank like was suggested?
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #8 of 9 Old 09-27-2013, 08:53 AM Thread Starter
Garage
Haven't made it that far. Have a 2 hr drive home then I'll do that.
SCT Livewire TS
post #9 of 9 Old 09-27-2013, 09:27 AM
Term3's Avatar
When you do drop the tank it's a real good time to install a sump and do the harpoon mod.
Term3 is offline
