6.0 over heat - Ford Powerstroke Diesel Forum
post #1 of 22 Old 09-23-2013, 08:29 AM Thread Starter
6.0 over heat
06 f-350 stock owned it about 3 weeks, runs great i tow a 17ft enclosed for my company real heavy, no problems untill i load my SCT programer when i do and pull hills it over heats, have to add coolant when it cools down, take program out same route does not overheat. any ideas? i have an EGR delete im going to put on and a new oil cooler.
edit, and when it happens no white smoke
tuffer70 is offline
post #2 of 22 Old 09-23-2013, 08:52 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Is there any white residue around the degas cap?
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 22 Old 09-23-2013, 12:10 PM Thread Starter
no sir, and forgot to say it has 150,000 miles
tuffer70 is offline
post #4 of 22 Old 09-23-2013, 02:35 PM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 235 Post(s)
Do you ever hear the fan engage? Most likely the water pump. Plastic impeller has spun on its shaft
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW See my visitor messages for my mods
Edge Insight & SCT X4 FOR SALE
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #5 of 22 Old 09-23-2013, 02:36 PM
Quoted: 235 Post(s)
Think about upgrading to a billet one from Bulletproof Diesel
post #6 of 22 Old 09-23-2013, 05:13 PM Thread Starter
yes the fan comes on, ok but what is the difference between pulling hills at 70 stock and 70 with the program? if the impeller has spun i would think it would over heat all the time pulling hard
tuffer70 is offline
post #7 of 22 Old 09-23-2013, 07:48 PM
Quoted: 50 Post(s)
Running a tune will cause the motor to run hotter when pulling a load, as more fuel, boost, and timing are being introduced to the motor. Most high power custom tunes tell you not to tow or haul anything when running such tunes, as the motor can heat up really fast - especially the EGTs. Tow tunes are designed for towing and usually keep EGTs in check, but even they are rated for a given load.
Is the "Engine Overtemp" alarm coming on? What are the ECTs and EOTs at which you think you are overheating? Failing head gaskets can also cause rapid ECT increases under load, as cylinder temps and pressures get introduced into the cooling system.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDC Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #8 of 22 Old 09-24-2013, 05:36 AM
Quoted: 235 Post(s)
Exactly. Sometimes a tune can bring to light problems you didnt even know you had
post #9 of 22 Old 09-24-2013, 06:12 AM
Soledad's Avatar
Garage
What SCT tune are you running when you pull the trailer?
2006 F-350 XLT FX4 SCLB 6.0L | TTY head bolts | stock EGR and cooler | blue spring FP mod | PHP Atlas 40 FICM tune | ScanGauge 2 & GlowShift 3-in-1 gauge (Boost/EGT/FP) | PMM coolant filter kit | Flo~Pro 4" turbo back w/muffler | stock tune
Soledad is offline
post #10 of 22 Old 09-24-2013, 04:38 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 443 Post(s)
Garage
How much coolant are you having to put in afterwards?
If you are not venting it out of the coolant recovery cap and you are not leaking anywhere its going somewhere.......
The dirty truth about programmers is: like stated above they can make small problems more noticeable. Tuners advance timing and increase cylinder pressure by several means boost is one.
It could be a head gasket problem, very slight issue with stock cylinder pressures. Crank up cylinder pressure and the leak will increase.
Best way to rule this out is by installing a 30 psi gauge into the cooling system. Normal pressures are around 10 psi + or- 3lbs. Any spikes in pressure under a heavy acceleration is a sure sign of combustion gases entering cooling system.
I hope this is not your issue, but you would be wise to investigate it.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
