degas bottle - Ford Powerstroke Diesel Forum
post #1 of 14 Old 09-22-2013, 11:18 AM Thread Starter
Exclamation degas bottle
i jus bought a 2007 f250. my 1st ford ever.. and my degas bottle leak a little bit around the cap.. i replaced the cap but after drivin it i pop the hood to check the cap and it b loose. wat causes this????? perhaps i need to replace the degas bottle??? or should i get scared of wat comes next?????:please :
1st ford is offline
post #2 of 14 Old 09-22-2013, 02:48 PM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Feedback Score: 3 reviews
Did you tighten it until the cap clicks?
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is offline
post #3 of 14 Old 09-22-2013, 03:23 PM Thread Starter
it dont click.. it tightens up and if u go any tighter then it get loose again
1st ford is offline
post #4 of 14 Old 09-22-2013, 05:17 PM
Quoted: 58 Post(s)
Sounds like it's time for a new degas bottle.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #5 of 14 Old 09-22-2013, 05:20 PM Thread Starter
I figured that... I was gettin scared that it was a gasket problem.. but imma still take it to get that pressure trst and all to check the head gaskets...
1st ford is offline
post #6 of 14 Old 09-22-2013, 11:07 PM
Blknite23's Avatar
my cap dosent click either ( Advanced Auto cap)... should it?
2006 CrewCab F250..
*Banks Big Hoss kit, Looney Wild, Studs, 6" with 37's other odds and ends
Blknite23 is offline
post #7 of 14 Old 09-22-2013, 11:19 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Bad cap.
Also bad cap.
Go to ford get an OEM cap. 14 bucks
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #8 of 14 Old 09-23-2013, 07:18 AM
jmoney330's Avatar
I'd have to disagree with getting an OEM cap. A lot of research says they are known to go bad.
I'd just go to autozone and get a $6 Stant cap!
Sold
2005 F250 SD SCLB. OEM Gaskets, ARP HeadStuds, EGR Delete. BulletProof Diesel 6-phase 58v FICM. Sinister Coolant Filter. STC Fitting, Blue Spring, Stand Pipes and Dummy Plugs. 35" Cooper Discovers on Ford Factory Rims. GlowShift Max Tow gauges. 3" Lift. SCT Livewire (Canned Tunes at the moment, soon to be Looney Tuned). Kensun 6000k Headlights & Foglights. Zoodad Mod. Problem child
jmoney330 is offline
post #9 of 14 Old 09-23-2013, 03:32 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
The old oe caps failed. Stant caps are garbage I went thru 3 of them
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #10 of 14 Old 09-23-2013, 03:52 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
I would agree the Stant caps aren't much better that the old Ford ones. I replaced my old Ford Cap (nothing wrong with it) with a Stant and occasionally I got drips. I put the old one back on an nothing ever drips out. So, when the original finally drips, an new Motorcraft will go back on.
However, with it reading like it is stripped, it might be time for a new degas bottle.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
