need help - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-21-2013, 02:14 PM Thread Starter
need help
Hey guys I just got three injectors new oil and egr cooler and I just got it back together drove it and something else it wrong. The turbo is farting pretty bad when I let off the throttle and the truck has no power. Also a p2263 code. Ford did the injectors because I had a high pressure oil leak. The oil cooler was showing restriction so I replaced it and the egr cooler because its original. The truck is a 2004 but built in 8/03. It has 188,000 miles. Ford only noticed those two problems. So what could it be now.
jpike1987 is offline
post #2 of 3 Old 09-25-2013, 12:45 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Can you monitor your VGT position? Seems likely to be stuck vanes in your turbo. Explain your no power a little more too...does it pick up power once you reach a certain rpm?
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 3 Old 09-30-2013, 07:10 PM
bondsman's Avatar
Clean the exhaust vanes and you will be good to go.
05 F250 4x4 CC, 9.5" Rize/Icon, 38" Toyos, 20x12 Pacers, 5" MBRP, AFE stage 2, Cass 190s, Powermax, ELC w/filter, RCD EGR delete
04 Excursion 4x4, vacation bus
Project 1979 F250 6.0 powered in progress
bondsman is offline
