occasional miss - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-19-2013, 05:16 PM Thread Starter
bigz's Avatar
occasional miss
my truck has developed a wierd miss at times... It seems to do it more before the engine is up to operating temp but i have noticed it doing it when engine was warm... its not a bad miss and it doesnt do it all the time, its a very random miss, not really sure how to describe it,
The truck doesn't throw any codes at all... any ideas where to start?
2005 King Ranch
arp head studs
bpd egr cooler
magnaflow duals
airaid intake
Looney tune by Vivian
edge cs monitor
xdp coolant filter
bigz is offline
post #2 of 4 Old 09-19-2013, 07:41 PM
jtaylor75's Avatar
It sounds like an injector is going south. You your SCT to see if you can pull a contribution code. If no luck then you will have to use and IDS to run a contribution test.
06 CCSB FX4 Lariat
Studded and Deleted, Warren 190/100s, Barder Stage 4, Built Trans, AIS Water/Meth, S&B intake, 4 inch Exhaust
Next:
A fuel system
jtaylor75 is offline
post #3 of 4 Old 09-20-2013, 02:40 AM Thread Starter
bigz's Avatar
well i just thought about it but my truck was at the dealer last week.... i checked it last night and yep the straegy is different... im hoping that its just interfering with my tunes causing my problem... got a email into vivian so we will find out
2005 King Ranch
arp head studs
bpd egr cooler
magnaflow duals
airaid intake
edge cs monitor
xdp coolant filter
bigz is offline
post #4 of 4 Old 09-20-2013, 05:51 PM Thread Starter
bigz's Avatar
well i was wrong it wasnt because of the strategy... looks like i have a injector problem... i have never fooled with the injectors on this truck... i changed them on my 7.3... are they set up similar or is this a different animal??
2005 King Ranch
arp head studs
bpd egr cooler
magnaflow duals
airaid intake
edge cs monitor
xdp coolant filter
bigz is offline
