Hard start (cold or hot) - Ford Powerstroke Diesel Forum
post #1 of 12 Old 09-18-2013, 06:03 PM Thread Starter
This has been happening more often latley. Cold of fully warmed up the truck takes several seconds to start. Sometimes its starts in a second like normal, other times it will just keep cranking. It always starts but it may take 2 or more cycles of the key to get it going.
Is there some common things I could look at? Its been getting worse over the years.
2005 6.0 with 167k miles
Thanks
AWD4g63 is offline
post #2 of 12 Old 09-21-2013, 01:26 PM Thread Starter
Also. Wen the night get in the 50s or lower the truck needs to be plugged in or its very hard to start.
Thanks for any help
AWD4g63 is offline
post #3 of 12 Old 09-21-2013, 02:07 PM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Feedback Score: 3 reviews
Have you checked FICM volts?
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is offline
post #4 of 12 Old 09-21-2013, 03:21 PM Thread Starter
No. I'm not familiar with diesel trucks. Do you know the specs
AWD4g63 is offline
post #5 of 12 Old 09-21-2013, 07:04 PM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Look at this video
If you don't have a monitor check the voltage like they do in the video, but if you do have a monitor set the FICM voltage as PID and check the voltage when the key is on but engine off, while cranking, and when the truck is running. The FICM voltage should never go below 46 volts. If it does you FICM is dying and you should probably have it replaced with a Bulletproofdiesel one or have your current one repaired by ed at FICMrepair.com
"Pickle Monster"
EGR MIA
CCSB
FX4
post #6 of 12 Old 09-21-2013, 07:23 PM Thread Starter
Awesome! Thank you
AWD4g63 is offline
post #7 of 12 Old 09-24-2013, 04:41 PM
x148's Avatar
Most likely have a small leak within the oil system , I would check stand pipes, stc fitting & dummy plugs especially if you have almost 200k on it.
05 F350
-Sinister EGR Delete
-Banks High Ram
-Blue Spring
-Air Dog II
-K&N Intake
-H&S Mini Max
-Swamps 58v FICM
-03 Turbo
-5" MBRP turbo back
-ARP Head Studs
-Cat ELC1 Coolant
-6" Lift on 37" Toyo M/T
-Detriot True-Trac with 4.56 Gears
-Pro Comp Trac Bars
x148 is offline
post #8 of 12 Old 09-24-2013, 06:13 PM Thread Starter
Damn. I don't understand this diesel talk. I don't know what any of the things you mentioned are. The truck has almost 170k on it.
AWD4g63 is offline
post #9 of 12 Old 09-24-2013, 06:15 PM
x148's Avatar
Sorry there pipes inside the engine that oil travels through, they have seals/o rings and they can leak and it can cause a long crank if that makes more sense.
05 F350
-Banks High Ram
-Blue Spring
-Air Dog II
-K&N Intake
-H&S Mini Max
-Swamps 58v FICM
-03 Turbo
-5" MBRP turbo back
-ARP Head Studs
-Cat ELC1 Coolant
-Pro Comp Trac Bars
x148 is offline
post #10 of 12 Old 09-24-2013, 06:24 PM Thread Starter
Thanks. That makes sense. Is there a port that you can test the system?
AWD4g63 is offline
