2004 6.0 DIesel Excursion won't start - Ford Powerstroke Diesel Forum
post #1 of 2 Old 09-17-2013, 04:36 AM Thread Starter
Running fine down the highway... then dead. Like it ran out of gas. Plenty of gas in tank. Brand new batteries and injectors. I can hear the fuel pump prime when the key is turned. Fuses and relays are fine. Any help out there?
FordGator is offline
post #2 of 2 Old 09-17-2013, 05:14 PM
bondsman's Avatar
You need to get a scanner to see if you have any codes like FICM performance. First thing I would look at is the high pressure oil system. If it is a late 04 (with ICP sensor on the passenger valve cover), check the STC fitting. Could be high pressure oil pump or IPR valve too.
Instead of throwing parts at it, find someone close by with an AutoEnginuity that can check the voltage of the FICM as well as the pressure of the high pressure oil system while cranking. Easy to diagnose/fix if you get the info from AutoEnginuity.
05 F250 4x4 CC, 9.5" Rize/Icon, 38" Toyos, 20x12 Pacers, 5" MBRP, AFE stage 2, Cass 190s, Powermax, ELC w/filter, RCD EGR delete
04 Excursion 4x4, vacation bus
Project 1979 F250 6.0 powered in progress
bondsman is offline
