help..ect vs oct - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-16-2013, 08:17 PM Thread Starter
help..ect vs oct
was told that oil cooler was plugging up on my 2004 f350 with the 6.0 powerstroke with 90000 miles based on ect/oct. I took tuck it in to a shop to get the trifecta ( flush coolant , add coolant filter, EGR del. and oil cooler replace). After all the work and a couple Gs. temp diff was still in the 20s while towing. took back to shop where thay flushed and back flushed for a couple of days(till filter was clean), removed radiator and sent so a shop to be cleaned and tested then replaced the oil cooler for the 2nd time. Driving home ect/oct was still 15 - 18 diff with no load driving @ 60 mph for @ 1 hour. dont know what to do at this point??any help would be greatly appreceated. thanks
ravlmv is offline
post #2 of 8 Old 09-16-2013, 09:04 PM
JustinOOO9's Avatar
Quoted: 474 Post(s)
Garage
could be a bad sensor(s)?
did they use vc-9 chemical to remove the iron and then restore plus to remove the sludge left over from ford gold coolant? and did they flush before? when people flush these trucks its good to drive it around for few days with just water if weather permits after the chemical flush. it takes a few days for all the iron scale/ rust to get out of your coolant system. really sorry for your trouble other than sensors or coolers i would wait to see what the guys with alot of experience here say...
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake.
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #3 of 8 Old 09-16-2013, 09:31 PM Thread Starter
not sure about the first time they did the flush, but when i brought it back they did 2 flushes with vc-9 then a couple of days of flushes and running with water till clear
ravlmv is offline
post #4 of 8 Old 09-16-2013, 09:40 PM
JustinOOO9's Avatar
Quoted: 474 Post(s)
Garage
well shoot man! if your serious about your truck bulletproofdiesel sells the air cooled conversion kit which will eliminate oil cooler clogs permanently... have you seen the videos about reverse flushing the oil cooler? one guy went from a 44 degree difference down to like a 16-15... cost him about $100 might be worth a short for ya in this situation i'll find the link real quick.
Justin,
post #5 of 8 Old 09-16-2013, 09:42 PM
JustinOOO9's Avatar
Quoted: 474 Post(s)
Garage
def. try this man! its exactly what im gonna do if my cooler ever starts to show signs... there are plenty of post on how to set it up too.
Coolant / Flushing Chronicles
Justin,
post #6 of 8 Old 09-16-2013, 10:00 PM Thread Starter
thanks for the great link. I forgot to mention that i also installed a bulletproof water pump, new tentioner, belt , degas bottle and cap. would love to be able to afford an external oil cooler but dont have that kind of$$. not sure what flushing or backflushing any more would do at this point? going to run for a couple of days and pull coolant filter and cut it openand check. i cant imagine that there could be anything in the cooling syst.
ravlmv is offline
post #7 of 8 Old 09-17-2013, 02:19 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
There is a procedure that Jurgernaut posted awhile back... I can't seem to find it right now. But it is how to test the EOT sensor and ECT. I'll try to find it for ya. Also, are you monitoring your deltas while unloaded, flat ground, while maintain a steady speed? What are the temps? I had a friend think the same thing and turned out his thermostat was stuck open so his deltas were out of range but once he put a new thermostat in his temps seemed to equilize.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #8 of 8 Old 09-17-2013, 05:18 PM Thread Starter
if you could find that procedure it would be great for checking sensors. thermostst was changed last month and taken off during the recent flushing and replaced. running 60 mph for @ 1 hour, flat ground and no load ECT rock solid at 190-192, OCT at 207-210. thanks for any help
ravlmv is offline
