pls help turbo? - Ford Powerstroke Diesel Forum
post #1 of 1 Old 09-16-2013, 02:45 PM Thread Starter
pls help turbo?
Ok so i am not sure what the problem is and really need to figure it out.. When i first got my truck i thought i was losing coolant so i took it in under warrenty.. So a couple days go by with ford having it and they say pressure check came up fine.. But they found some codes without my light being on not quiet sure of what the codes were but they ended up replacing the turbo,egr valve, and 4 injectors. I get my truck and i put an exhaust on and did the egr delete with the oil cooler.. Everything came apart and went together perfect with no issues at all.. Start her up ran fine but now it seems like im getting some type of sputtering or something.. Whatever it is its effecting my boost and power. When the issue occurs like i said i wont have any power and the boost will be bouncing around like its pegged at around 5-10 psi trans will shift then boost will climb to max boost. Also will get white smoke with all of this. one more thing is the other day i noticed the up pipe is leaking from the right header but i dont think that is causing this problem.. any help is appreciated and sorry for the book
phillygp61 is offline
