is there an injector test once the injector has been removed? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-15-2013, 06:05 PM Thread Starter
Quoted: 2 Post(s)
The title says it all. I have a 2005 6.0 with 240k. Shop says I need injectors 6 and 8 (for starters). Injectors 1 and 4 are also giving a soft code. Maybe bad injectors or FICM, according to the shop. I started to take out injectors 6 and 8 and noticed that injector 6 was not plugged in. Well crap. now I have a 200 dollar injector coming I may not need plus my current injector has a 125 dollar core charge that I wont get back until I return it. But why return an ok injector. Maybe put it in a position that is actually bad. Like position 1 or 4 maybe. Hell I dont know. At this point in teardown, no prob to remove injectors. Can I test them individually and removed? Can shops do this? thank you
PS. Why can't the shop scanners tell the difference between an injector that is bad and a one that is unplugged?
soapthedog45 is offline
post #2 of 3 Old 09-15-2013, 06:37 PM
While there is equipment made that will test injectors out of the engine few injection rebuild shops have them. Very exspensive I was once told by our local guy the machime was like 60k he did not get enough 6.0 injectors to be economicaly feaseable.
I did find a single injector tester from China thru a web search but it was $1200.
Most scanners will say if it is a short; open circuit but can't distinguish why it is open.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 3 Old 09-15-2013, 06:43 PM
back in the saddle
shu873's Avatar
At 240k I would replace them all. If one or two goes bad and you just replace those now, you'll be back in there sooner than later doing others. With that mileage they've had a good long life. Only way I would just replace 1 or 2 is if I were getting rid of the truck.
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
Tags
injector
