New motor, new injectors, 15min later rough idle - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-14-2013, 08:35 AM Thread Starter
Stoker0560's Avatar
Looking for some insight as to which direction to look, 05 f250, new short block new ford heads, new (rebuilt) warren 155s stock injectors blue spring l, First start up of new engine motor popped off and sounded great!! No codes no misfires ran beautifully, idle time was limited but enough to verify everything was ok.. So we set out for the first test drive and before we hit the street truck developed a miss, thought maybe we had some air in the oil rails so we went around the block and miss never went away,
Cylinder contribution test showed number 7 had very low contribution, ran injector buzz test and no codes, next day took truck around the block again and still couldn't get number 7 to light up. Briefly checked conections and anything obviouse but found nothing.. I ended up unplugging #7 injector during idle and it made zero change in the idle..
So obviously I'm getting nothing from number 7, my question is where do I start, obviously I'm getting signal to the Injector as buzz test was good but I don't know why the injector won't fire, motor has never made any sound or negative action to indicate cylinder damage.. Or compression issues, it's just flat dead! I suppose I might swap 5 and 7 injectors and see if the problem follows the injector but was hoping someone might have a few tips or other things to try first before I tear back into it.. Thanks! Oh and FICM voltages are spot on!
09 F450 CC LB lariat 6.4 black on black 23k miles, stock.. (For now)...
97 F250 SC LB 4x4 7.3 05 Superduty axels, 18" King Ranch Rims, "under the knife"
Former 6.0 Owner. (05,05,03)
Stoker0560 is offline
post #2 of 6 Old 09-14-2013, 09:11 AM
Quoted: 818 Post(s)
Did you follow Ford's TSB for anytime you do anything to the HPOP system. You need to make 5-10 short wot runs to be sure all air is out of the system.
Corey@CNCFAB is offline
post #3 of 6 Old 09-14-2013, 09:31 AM Thread Starter
Stoker0560's Avatar
No wot runs as there is a break in on the block and its not quite ready for WOT passes just yet, at least not IMO, Ive had bleed out issues before with air in the system but never had it last this long nor consistently one cylinder like this.. Thanks for the advice though, I might drive it some more and see if it clears up..
post #4 of 6 Old 09-14-2013, 03:10 PM Thread Starter
Stoker0560's Avatar
Well just to post my findings I ended up swapping number 5 and 7 injectors and re-assembled, put my scan tool on and fired it back up and sure enough my low contribution followed the injector.. So new injector and we should be back in business!
Glad they are warrens, great warranty and great customer service! Hey there 6.0 injectors.. Can't expect them all to be perfect regardless of who rebuilds them..
post #5 of 6 Old 09-14-2013, 10:14 PM
Quoted: 818 Post(s)
:thumbup:
post #6 of 6 Old 09-20-2013, 04:53 AM Thread Starter
Stoker0560's Avatar
Welp got another injector sent out, I pulled number 7 back out (which originally was number 5) to install new o rings n washer, I put it back in number 7 cylinder and I stalled the new Injector into number 5 cylinder. Got it all putback together and fired it up and cylinder contribution test shows number 5 is very low, I unplugged number 5 harness and could hear the "clicking " of the injector quit but truck ran just the same..
Any ideas guys? I can't imagine I got two bad Injectors??
