Stuck thermostat - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-14-2013, 06:37 AM Thread Starter
c dog's Avatar
Stuck thermostat
My EOT & ECT have always been with in a 5-7 degree difference. My SCT livewire needs repair so my iphone can only monitor ECT. This morning I was driving home from work an stopped and pulled over 2 times and idled for about 20 mins each. My ECT was about 195-199 degress then after idling for 20 mins it goes to 220-225 (83 degree weather). This happened both times. When I start driving the fan kicks in and the temps drop back to 195-199 with in about 1-2 mins going about 40-45 MPH.
The fan looks to be spinning normal at idle as before.
Is this a sign of a stuck thermostat?
Sent from AutoGuide.com App
c dog is offline
post #2 of 7 Old 09-14-2013, 07:34 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
There is certainly something going on there and I would start with a new thermostat. The Motorcraft thermostat fails open normally and causes the engine to run cooler than normal usually. Not sure what is happening with yours but it is a cheap thing to change out. Is your coolant level where it should be?
RIP Mitch
the Org crew
PGreenSVT is offline
post #3 of 7 Old 09-14-2013, 07:41 AM
Term3's Avatar
Yes it could be a bad thermostat but if it is a Ford stat I've personally only seen them fail open. That being said its a cheap and easy swap so I'd start there. If you know someone with something like an AE you could check out the fan clutch engagement. A missing EGR valve can cause the clutch to not reach full engagement with some flash versions but this doesn't sound like your issue.
LOL I basically just said what you said PG but I type a lot slower on this small screen.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #4 of 7 Old 09-14-2013, 08:08 AM
ZMANN's Avatar
Quoted: 1472 Post(s)
so the fan or driving at speed will drop temps ?
I would also be considering the water pump impeller on my check list if you can't find any other issue
We Miss you Ronnie
ZMANN is offline
post #5 of 7 Old 09-14-2013, 08:34 AM Thread Starter
c dog's Avatar
"so the fan or driving at speed will drop temps ?"
Yes. I took out the thermostat and going to go get a new one now
c dog is offline
post #6 of 7 Old 09-14-2013, 08:49 AM
ZMANN's Avatar
get OEM
housing and all is 1 piece
We Miss you Ronnie
ZMANN is offline
post #7 of 7 Old 09-14-2013, 04:45 PM
jaysshortbus's Avatar
Question
Not to hijack your thread but mine never gets above 188 unless I am on Highway going 80 for awhile and I replaced thermostat yesterday and switched to ec-1 coolant and still same outcome so I cold soaked it last night and this morning ect was 46 eot was 47 and outside temp on display in truck was 52 !! So dont know if I need to replace both sending units or whats up !!.
Jay
jaysshortbus is offline
