Water pump replacement - Ford Powerstroke Diesel Forum
post #1 of 11 Old 09-12-2013, 08:16 PM Thread Starter
06kngrnch84's Avatar
Hey guys I'm looking for a good step by step guide for water pump replacement. Instructions, tools needed and tips from y'all that have done it that may make it easier on me. Any help is appreciated.
Jackson, MS. 2006 Ford F-350 SRW King Ranch FX4 Crew Cab, All Stock, 160,000 miles
EGR Delete
Updated HPOP Fitting
Updated Standpipes and Dummy Plugs
ELC Coolant
Coolant Filter
Scan Gauge II
New Oil Cooler
Blue Spring Kit
'04 Metal Cold Side CAC Tube
06kngrnch84 is offline
post #2 of 11 Old 09-12-2013, 08:19 PM
ZMANN's Avatar
Quoted: 1469 Post(s)
look around for some step by steps
it was easy a few tricks and I did my radiator while I was there just for PM
it makes the pump a cake walk
no special tools
We Miss you Ronnie
ZMANN is online now
post #3 of 11 Old 09-12-2013, 08:20 PM
ZMANN's Avatar
WATER PUMP REMOVAL INSTRUCTION w/PICS. - TheDieselGarage.com
We Miss you Ronnie
ZMANN is online now
post #4 of 11 Old 09-12-2013, 09:51 PM Thread Starter
Thanks. Any suggestions on coolant from anybody. I did a complete flush a couple years ago during my oil cooler/egr delete process and I went with prestone heavy duty, seemed to work good but I can't find it now, so guess ill be doing another complete flush. Napa has a Zerex GO5, anybody used this? Is it best to go with the 50/50 or concentrate?
EGR Delete
ELC Coolant
Coolant Filter
Scan Gauge II
New Oil Cooler
Blue Spring Kit
post #5 of 11 Old 09-12-2013, 10:29 PM
Term3's Avatar
http://www.rvcruzer.com/docs/CatELC.pdf
After a good flush, as per the Tech files, add concentrate or you'll end up on the weak side. I do a 60/40 ratio.
http://www.engineeringtoolbox.com/et...col-d_146.html
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #6 of 11 Old 09-13-2013, 12:25 PM Thread Starter
The pic below shows what I drained out of my radiator... doesn't look right to me?? Especially since what I put in was a bluish-purple color. This looks rust colored to me and when I pulled the top hose off that goes to the thermostat it was the same color inside and also looked dirty. Whats my problem here?? I probably don't want to know the answer but give it to me anyway. Lol!! Thanks
EGR Delete
ELC Coolant
Coolant Filter
Scan Gauge II
New Oil Cooler
Blue Spring Kit
post #7 of 11 Old 09-13-2013, 12:26 PM Thread Starter
Here's the pic. Don't think it loaded the first time
EGR Delete
ELC Coolant
Coolant Filter
Scan Gauge II
New Oil Cooler
Blue Spring Kit
post #8 of 11 Old 09-13-2013, 01:52 PM
Term3's Avatar
Yuk, looks like you need to do a complete chemical flush with Restore and Restore+.
Term3 is offline
post #9 of 11 Old 09-13-2013, 02:02 PM Thread Starter
Did that about 2 years ago but guess ill dive in again.
EGR Delete
ELC Coolant
Coolant Filter
Scan Gauge II
New Oil Cooler
Blue Spring Kit
post #10 of 11 Old 09-13-2013, 05:11 PM Thread Starter
Think I found the source of the "rust" colored coolant. Take a look at the pics. Don't know if y'all can tell but around the inner ring where the gasket sits pieces of that have chipped off !!!
ID:	167337   Click image for larger version
ID:	167345   Click image for larger version
EGR Delete
ELC Coolant
Coolant Filter
Scan Gauge II
New Oil Cooler
Blue Spring Kit
