Sediment in degas bottle - using CAT ECT-1 - Ford Powerstroke Diesel Forum
post #1 of 14 Old 09-12-2013, 03:21 PM Thread Starter
I bought my truck (2005 F-250 CCSB) in April and she's been good to go aside from an expensive fix for a leaking up pipe and a crapped out FICM. Already had head studs and EGR delete at time of purchase.
I've been saving up for a coolant filter and verified that I'm already running that good red stuff. Looked in the degas bottle today and saw a bunch of sediment in there. Not sure if it's casting sand or what.
I'm just wondering how I should best deal with this situation. Get a filter and do a coolant flush? Try to suck/dump that crap out and add more coolant and get a filter?
I just don't want to do something to kill the oil cooler and open that can of worms.
2005 F-250 Lariat CCSB 4x4 -
ARP Headstuds
EGR delete
Blue Spring
Edge CS
Sinister Coolant Filtration
4" Diamond Eye Turbo Back, Straight Through
6.0_n00b is offline
post #2 of 14 Old 09-14-2013, 02:43 AM Thread Starter
Bump
Anyone?
ARP Headstuds
EGR delete
Blue Spring
Edge CS
6.0_n00b is offline
post #3 of 14 Old 09-14-2013, 05:15 AM
Quoted: 58 Post(s)
Add a coolant filter and let it take care of removing the contaminants from the cooling system. Do it sooner than later, because until you do your OEM oil cooler is acting as your coolant filter.
I ran a coolant filter for 3 years until recently upgrading to the BPD oil cooler. The first few filter changes contained a lot of sediment/silicate.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #4 of 14 Old 09-14-2013, 05:23 AM Thread Starter
That's the route I was pretty set on. I thought about trying to suck some of it out with a turkey baster or something too, maybe not a good idea though.
My deltas are good so at least I know the oil cooler is in fairly good health.
ARP Headstuds
EGR delete
Blue Spring
Edge CS
6.0_n00b is offline
post #5 of 14 Old 09-14-2013, 06:47 AM
Term3's Avatar
You can easily make your own coolant filter for a LOT less then the billet ones you see a lot of diesel shops sell. My not look as purdy but will do exactly the same thing.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #6 of 14 Old 09-14-2013, 06:51 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
I was kinda wondering after so many miles and so many clean filters if the coolant filter becomes a waste of space and money. Couldn't we just take it off once we clean things up?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 14 Old 09-14-2013, 06:54 AM Thread Starter
I'm considering making my own. I'm just concerned about the durability of those filter housings though. Somebody in another thread said something about them rusting after a couple years. Dieselsite sells just the housing, but $65 seems a bit much
ARP Headstuds
EGR delete
Blue Spring
Edge CS
6.0_n00b is offline
post #8 of 14 Old 09-14-2013, 06:59 AM
Term3's Avatar
If you still have the OEM oil cooler I would leave it on. I've always run a coolant filter with CAT ELC coolant and I'm still on my original oil cooler after 190,000. Most of the guys I know are on their second.
Term3 is offline
post #9 of 14 Old 09-14-2013, 07:08 AM
Quoted: 58 Post(s)
Mine was recently removed when the BPD oil and EGR coolers were installed. Freed-up a little space in the engine compartment. The last couple of coolant filters didnt contain any debris anyway...
Carli Radius Arms
Carli Track Bar
Previous:
All the BPD goodies
skanj0 is offline
post #10 of 14 Old 09-14-2013, 07:19 AM
Term3's Avatar
If its rust on the outside your concerned about, spray paint it. If its rust on the inside, you have bigger problems.
Term3 is offline
