Water in fuel, engine missing - Ford Powerstroke Diesel Forum
post #1 of 12 Old 09-11-2013, 05:52 PM Thread Starter
06kngrnch84's Avatar
Ok guys got a new problem and looking for some help. A few months back I started getting the "WATER IN FUEL" light all the time. Drained the filter housing but didn't look like any water came out, usually I can tell bc the water seperates from the fuel, but the light stop coming on...... for about 3 days. It started again so this time I get new filters, drained again and install new filters. Filters that were in were only had about 6000 miles on them, usually change them every 8-10. This did not help the light still came on, so I thought maybe a sensor error??? Anyway, about a week after this I started getting a miss, started off small and has now started to be pretty bad. Starts good but is missing badly while idling. Jumps and misses while accelerating but when I go WOT it is perfect, good power and all. While cruising at really any speed I can feel it missing and when I stop to idle it seems the worst. I noticed this weekend while on about a 60 mile drive that my FICM would periodically drop to 47.5, it would automatically jump back up to normal 48-49. I checked my FICM while starting and at WOT, it held 48-49. Only time it drops is while I'm cruising or idling from time to time. I use power service every time I put fuel in the tank. Needing to know what I need to check and how to check it. I'm going to be digging into it sometime this weekend to put a new water pump on, don't think a failed water pump would cause this but I could be wrong. Any help is appreciated.
AutoGuide.com Free App
Jackson, MS. 2006 Ford F-350 SRW King Ranch FX4 Crew Cab, All Stock, 160,000 miles
EGR Delete
Updated HPOP Fitting
Updated Standpipes and Dummy Plugs
ELC Coolant
Coolant Filter
Scan Gauge II
New Oil Cooler
Blue Spring Kit
'04 Metal Cold Side CAC Tube
06kngrnch84 is offline
post #2 of 12 Old 09-11-2013, 07:44 PM
jtaylor75's Avatar
take the fuel pump drain plug out and spray some break cleaner (with a straw) in the hole and watch all the nasty brown rusty nasty crap come out. This will stop the WIF light issue. Hopefully it didnt make it to the injectors. What does your fuel pressure look like?
06 CCSB FX4 Lariat
Studded and Deleted, Warren 190/100s, Barder Stage 4, Built Trans, AIS Water/Meth, S&B intake, 4 inch Exhaust
Next:
A fuel system
jtaylor75 is offline
post #3 of 12 Old 09-11-2013, 07:52 PM Thread Starter
The fuel pump drain plug? Is this the same as what I was referring to as the fuel filter housing under the truck on the frame or is this different? I do not have a fuel pressure gauge, I been planning to get one but funds haven't allowed it
EGR Delete
ELC Coolant
Coolant Filter
Scan Gauge II
New Oil Cooler
Blue Spring Kit
post #4 of 12 Old 09-11-2013, 08:28 PM
jtaylor75's Avatar
yes, its the HFCM drain plug. (the one under the truck)
06 CCSB FX4 Lariat
Next:
A fuel system
post #5 of 12 Old 09-11-2013, 08:47 PM Thread Starter
Should I take the filter out before doing this or just do it with the filter installed? And I do know that when I changed the filters the top filter was a little dirty but I sucked some of the diesel out of that top housing and it was very clean
EGR Delete
ELC Coolant
Coolant Filter
Scan Gauge II
New Oil Cooler
Blue Spring Kit
post #6 of 12 Old 09-11-2013, 09:12 PM
JustinOOO9's Avatar
Quoted: 522 Post(s)
Garage
on the frame rails mounted fuel filter there is two things to check...
1. the large black cap that covers the filter element and then a small maybe brass-colored hex head screw... unscrew that and clean out the little cavity. alot of people found tha somehow the plug was corroded and left nasty rush/water/fuel junk in there.
also looking up the infmous "powerstroke tank delamination problem" not a common as the article makes it out to be but if you changed all your sensors, the drain, filters, pump its gotta be the fuel tank or source of fuel your fueling up i think.
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #7 of 12 Old 09-11-2013, 09:24 PM
jtaylor75's Avatar
i did it with the filter installed, although im sure it wouldnt hurt to take the filter out and give that housing a good spray too.
06 CCSB FX4 Lariat
Next:
A fuel system
post #8 of 12 Old 09-12-2013, 11:58 AM Thread Starter
Ill do this tomorrow. Ill let ya know if it helps or not. Thanks
EGR Delete
ELC Coolant
Coolant Filter
Scan Gauge II
New Oil Cooler
Blue Spring Kit
post #9 of 12 Old 09-12-2013, 12:30 PM
Term3's Avatar
Quoted: 2 Post(s)
A buddy that borrowed my truck not long ago got a bad tank of gas that ran the exact same way. He was smart enough to take the drain plug out right away but with the water in the tank sloshing around it would only get picked up every so often. The dealer he took it to we're stupider then he was and replaced an injector and sent him on his way only to have the water in fuel light come on a couple of days later, dealer kept saying they took a fuel sample and saw no water and kept putting in another injector. Pulled the drain plug again but the light came back on after about an hour of driving (which would idle and run fine at first then get much worse). After making the dealer drop the tank to get the rest of the water (and a$$ dealer said they were wrong when they said there was no more water) out the truck runs ok now, $5,000 later. DROP YOUR TANK
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #10 of 12 Old 09-29-2013, 06:26 PM Thread Starter
So I pulled out the filter and the drain plug and cleaned out the HFCM. No more "water in fuel light" so far. The missing cleared up right after I did it but came back after a few days. Not sure whats going on. Thinking maybe time to get injectors checked.
EGR Delete
ELC Coolant
Coolant Filter
Scan Gauge II
New Oil Cooler
Blue Spring Kit
