Turn key nothing happens. - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-11-2013, 05:48 PM Thread Starter
Just finished replacing a 6.0 in an 05 F350. When I turn the key nothing happens ,no cluster lights, engine does nothing. radio,lights ,blinkers all work. Any Ideas?
midnite is offline
post #2 of 3 Old 09-12-2013, 06:14 PM
bondsman's Avatar
Check all of your grounds. Especially the two on the drivers side (one behind the abs module and other one on the firewall behind the customer access wire ends). Check the connectors for the FICM and PCM. But those grounds will definitely cause a non crank and dead cluster issue.
05 F250 4x4 CC, 9.5" Rize/Icon, 38" Toyos, 20x12 Pacers, 5" MBRP, AFE stage 2, Cass 190s, Powermax, ELC w/filter, RCD EGR delete
04 Excursion 4x4, vacation bus
Project 1979 F250 6.0 powered in progress
bondsman is offline
post #3 of 3 Old 09-14-2013, 05:50 AM Thread Starter
Found a fuse missing.
midnite is offline
