06 F-250 substantial oil leak and slight rough idle - Ford Powerstroke Diesel Forum
post #1 of 2 Old 09-10-2013, 04:02 PM Thread Starter
workin350's Avatar
Hopefully the techs in this forum can point me in the right direction. I do most of my work myself and a lot of research before I start throwing parts at a problem so I'm looking for either confirmation of my suspicions or a different diagnosis to check into.
symptoms:
Oil Leak appears to be coming from front and back of intake. There is some on sides of motor. Enough of a leak to leave a spot the size of a place mat when parked for 8 hrs or more.
Idle is not necessarily rough but not right and can hear light popping sound occaisonaly during idle. Truck runs fine has good power not throwing any codes.
From what I've been seeing in research I'm thinking it's the ICP sensor but I'm hoping for some confirmation on that theory. And I believe on my motor it is on the front of the passengers side valve cover. If you don't beleive that I'm on the right track please feel free to point me in the right direction. Thank you all for your help
workin350 is offline
post #2 of 2 Old 09-15-2013, 06:24 AM Thread Starter
workin350's Avatar
hello?????? I'm sure this question has been on this forum before but i would really appreciate at least some kind of response
